Question about Optics
Daystate mk3 changing power settings - Optics
What is the most powerfull air rifle and fps
80 ft lbs air ranger from daystate
Jun 23, 2017 | The Optics
Is the daystate wolverine b 22 12ft/lbs rifle under power compared to other 12ft/lbs out there
No it is a Daystate and will be as close to 12 ftlb as the law requires as all air rifles that are non FAC are
Mar 17, 2015 | Optics
How to increase power to my daystate mk3 air rifle
Get a new air rifle with more power?
Dec 29, 2013 | Optics
How to increase power on my daystate mk3
Basic power supplies should be 400 to 1000 Watts for current systems. A 230W supply is Underpowered and may not support the hardware devices all that well. In addition, the Video drains power, so a Video card with 2G Ram will help speed up the process. Then an additional Power RAM (Memory) with speed available to your system; helps increase activity. Cooling Fans help reduce HEAT that also slow down operations. Clean the inside of the computer as dirt., dust and dust balls collect and keep the electronics hot.
Dec 29, 2013 | Enhance Technology ATX-1123B, Enhance...
How do I change the springs on front of my vw polo mk3
on the mk3 vw you just loosen the 7mm allen bolt on top (might need to shock it loose with air tools) and then when that bolt is loose you can jack the car up without needing spring compressors. the rest of the mounting bolts at the bottom you can loosen afterwards. fitting is reversal.
Sep 10, 2010 | 1994 Volkswagen Golf
When i step on the gas the power is there then it
You know you should have it scanned for codes.
May 07, 2010 | 1999 Volkswagen Jetta
Ford mondeo mk3, intermitent dumping of water from cooing system,found crack in header tank, changed same,ran car at idle, temp guage at normal & heater blowing hot , took car for run , temp guage off...
You may have an air pocket in your system which some times happens.  One way to get rid of it is to take the upper hose off on the engine side,  fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight.  Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
Mar 09, 2009 | 2001 Ford Taurus
Bushnell sportview 4x12x40
daystate is based in the UK so you may not like this answer too much. The oldest manual for daystate rifles and accessories only go back to 97'. however, here is their contact info to try for some help from the people who might send you the manual in paperback or mabey as a pdf if you email them. +44(0)1782 791755 their phone and sales@daystate.co.uk email link. it's worth a try. otherwise you may find someone who owns your rifle mode on their site's forum
Feb 18, 2008 | Optics
Optics Logo
Top Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
