Question about Frigidaire FEF336BC Electric Kitchen Range
How to remove thermostat on PLEF398C
  • Official Brand Answer
  • 4,342 Answers
Hello Edward, thank you for your post!
Remember, these intricate part replacements do require precision and patience, therefore when replacing parts that require the exchange of electrical wiring harness or removing your range, I always suggest seeking professional advice. One must be very careful as these replacements can lead to any potential harm.
Best regards!
Posted on Jan 06, 2014
Where is the thermostat in a oldsmoble alero?
3.4L Engine
  1. Remove the thermostat housing to intake manifold bolts.
  2. Remove the thermostat housing outlet and thermostat
3.1L Engine
  1. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  2. Remove the thermostat.
2.2L Engine
  1. Remove the thermostat housing to water pump feed pipe bolts.
  2. Remove the thermostat housing to water pump feed pipe.
  3. Remove the thermostat.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 02, 2011 | 2000 Oldsmobile Alero
How to get the thermostat housing to disconnect. We have taken all bolts loose but will not come apart.
Not sure if you have the 2.7L or the 3.5L so I'll post for both sizes for you:
2.7L Removal procedures
  1. Drain cooling system.
  2. Remove radiator lower hose from thermostat housing.
  3. Remove nuts from heater tube flange studs.
  4. Loosen starter bolt at heater tube bracket.
  5. Pull heater tube out of thermostat housing and position out of the way.
  6. Remove bolt and two studs.
  7. Remove thermostat housing, O-ring and thermostat.
  8. Remove thermostat housing bolts.
3.5L Removal procedures
  2. Raise vehicle on hoist.
  3. Disconnect electrical connectors from engine oil and power steering pressure switches.
  4. Disconnect radiator and heater hoses from thermostat housing.
  5. Remove thermostat housing bolts.
  6. Remove housing, thermostat, and gasket.
NOTE:
The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing
May 07, 2011 | 2003 Dodge Intrepid
Where is thermostat on my 2005 chevy classic
Thermostat Removal & Installation 2.2L Engine 2004-2005 To Remove:
  2. Remove the thermostat housing-to-water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
  3. Remove the water pump feed pipe from the thermostat housing .
  4. Remove the thermostat from the housing.
To Install:
  1. Install the thermostat on the housing.
  2. Install the water pump feed pipe on the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Fill the cooling system.
2006-2007 To Remove:
  1. Drain the cooling system.
  2. Disconnect the radiator outlet hose from the surge tank and thermostat housing cover. Thermostat & cover gm-03-39-3601.gif
  3. Remove the mounting bolts and remove the thermostat housing cover.
  4. Remove the thermostat from the housing. Discard the O-ring.
To Install:
  1. Using a new O-ring, install the thermostat on the housing.
  2. Install the thermostat housing cover with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the surge tank and thermostat housing cover.
  4. Fill the cooling system.
3.5L Engine (LZ4) W/ Variable Valve Timing & 3.9L Engine To Remove:
  2. Remove the air cleaner outlet duct.
  3. Disconnect the radiator outlet hose from the thermostat housing. Thermostat 3.9L gm-03-00-3054.gif
  4. Remove the mounting bolt/stud and remove the thermostat housing.
  5. Remove the thermostat from the engine.
  6. Clean the sealing surfaces.
To Install:
  1. Using a new gasket, install the thermostat on the engine.
  2. Install the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the thermostat housing.
  4. Install the air cleaner outlet duct.
  5. Fill the cooling system.
  6. Check the cooling system for leaks.
3.5L Engine (LX9) W/O Variable Valve Timing To Remove:
  1. Drain the coolant.
  2. Disconnect the radiator hose from the thermostat housing. Thermostat 3.5L gm_mv_ven_tstat.gif
  3. Remove the mounting bolt/stud and remove the thermostat housing.
  4. Remove the housing gasket.
  5. Remove the thermostat.
  6. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine.
  2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
  3. Connect the radiator hose to the thermostat housing.
  5. Check the cooling system for leaks.
Jan 29, 2011 | 2005 Chevrolet Malibu
Thermostat replacement 2002 rendezvous
Thermostat Removal & Installation 3.4L & 3.5L Engine To Remove:
  1. Drain the coolant below the level of the thermostat.
  2. Remove the air cleaner and duct assembly.
  3. Remove the exhaust crossover pipe.
  4. Disconnect the radiator hose from the thermostat housing. gm_mv_ven_tstat.gif
  5. Remove the mounting bolts and remove the thermostat housing.
  6. Remove the housing gasket.
  7. Remove the thermostat.
  8. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine. NOTE: Apply RTV sealer to the thermostat housing bolt threads.
  4. Install the exhaust crossover pipe.
  5. Install the air cleaner and duct assembly.
  6. Fill the cooling system.
  7. Check the cooling system for leaks.
3.6L Engine To Remove:
  1. Remove the air cleaner.
  2. Remove the throttle body.
  3. Remove the heater pipes.
  5. Remove the thermostat mounting bolts and remove the thermostat.
  6. Clean the thermostat and heater pipe mating surfaces.
To Install:
  1. Place the thermostat in the housing with a new gasket.
  2. Install the thermostat and gasket on the engine with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Install the coolant inlet pipe.
  4. Install the heater pipes.
  5. Install the throttle body.
  6. Install the air cleaner.
  7. Fill the cooling system and perform a leak test.
Dec 19, 2010 | 2002 Buick Rendezvous
Where to locate the thermostat on an 03 pontiac grand am?
Not sure which engine you have so please pick the appropriate engine:
2.2L Engine
  1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
Thermostat mounting-2.2L engine
3.1L Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Disconnect the surge tank line from the thermostat housing.
  5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  6. Remove the thermostat.
3.4L Engine
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
Nov 01, 2010 | 2003 Pontiac Grand Am
What do i do when its over heating? how do i install thermostat?
To Install:
To Install:
Sep 18, 2010 | 2002 Pontiac Aztek
Please choose the correct steps for the size of engine that you have:
4.5L & 4.9L Engines
  1. Drain the coolant to a level below the thermostat housing.
  2. It may be necessary to remove the upper air filter assembly on some models.
  3. Remove the 2 bolts securing the upper thermostat housing to the lower housing.
  4. Remove the upper thermostat housing.
  5. Remove the thermostat and O-ring from the lower housing.
Thermostat installation—4.5L and 4.9L engines
To install:
  1. Install the thermostat and a new O-ring to the lower housing.
  2. Install the upper thermostat housing to the lower housing. Tighten the thermostat housing bolts to 20 ft. lbs. (27 Nm).
  3. Refill the cooling system using a 50/50 mixture of water and ethylene glycol antifreeze.
  4. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
4.6L Engines
  2. On some vehicles, access is easier if the front-end beauty panel and the air cleaner are removed.
  3. Remove the 2 bolts securing the thermostat housing to the intake manifold.
  4. Remove the thermostat housing.
  5. Remove the thermostat and O-ring from the housing.
Thermostat installation—4.6L Engine
Loosen the upper radiator hose clamp at the thermostat housing
Remove the upper radiator hose clamp from the thermostat housing
Remove the thermostat housing retaining bolts and . . .
. . . remove the thermostat housing from the engine
Separate the thermostat from the housing
To install:
  1. Install the thermostat and new O-ring to the housing.
  2. Install the thermostat housing to the intake manifold. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  4. Install the air cleaner and beauty panel, if removed.
  5. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
May 23, 2010 | 1996 Cadillac DeVille
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
How do I remove the thermostat from my 2001 chevy venture
2001 Chevrolet Truck Venture FWD 3.4L SFI 6cyl
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
    Fig. Remove the housing bolts
  6. Remove the thermostat housing and gasket.
To install:
Fig. The removal and installation of the thermostat
  1. Install the thermostat.
  2. Install the thermostat housing and gasket.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  4. Install the radiator hose to the thermostat housing.
  5. Install the crossover exhaust pipe.
  6. Install the air cleaner and duct assembly.
  7. Fill the cooling system.
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the air cleaner intake duct.
  3. Partially drain the cooling system.
  4. Remove the radiator inlet hose from the thermostat housing.
  5. Remove the thermostat housing bolts.
  7. Clean and inspect the thermostat housing gasket mating surfaces.
To install:
  2. Install the thermostat housing.
  3. Install the thermostat housing bolts and tighten to 18 ft. lbs. (25 Nm).
  4. Install the radiator inlet hose to the thermostat housing.
  5. Install the air cleaner intake duct.
  7. Start the engine and check for leaks.
3.9L Engine
  3. Release the tension on the hose clamp at the thermostat housing and remove coolant hose.
  4. Remove the thermostat housing mounting bolts and remove the thermostat housing.
    Fig. Remove the thermostat housing to access the thermostat-3.9L engine shown
To install:
  2. Install the thermostat housing and tighten the bolts to 18 ft. lbs. (25 Nm).
  3. Install the coolant hose to the thermostat housing and install the hose clamp.
  4. Refill the cooling system to the correct level.
  5. Start the engine and check for leaks.
I hope help you whit thie (remember rated this help) Have a nice day and good luck.
Sep 23, 2009 | 2001 Chevrolet Venture
Frigidaire FEF336BC Electric Kitchen Range Logo
52 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
