Question about HP WX412AA Mouse
Wireless hp mouse
How to set up using a dvr
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
I have a samsung np-nf110/nf210/nf310 , os is windows 7 starter. i wanted to use my HP wireless optical mobile mouse but it doesn't seem to work or i dont think it connected. batteries are brand new and...
we dont do Samsung here, its HP
but HP mouse with no model stated, is impossible to be accentuate.
its a wireless mouse right, you left only small hint.
battery powered wireless mouse ,.by HP
windows 7
wireless mouse, HP and Samsung.
that takes 2 working drivers to make that work. both HP
the USB side and the mouse side.
HP does not support this on non HP computers so windows 7 is the only hope, MICROSOFT PLUG AN PLAY
you must be connected to the internet or its all just a wasted of time,
do so.
then plug both those things in.
the PC goes Dingdog sound telling you its found a new USB device.called wireless mouse HP, (no model stated)
then tries to find a driver on the web, MS servers for that.
if it can find one, then good luck, doing that. as the HP drivers will not like your PC
as here, if this is possible at all.
https://h30434.www3.hp.com/
Jul 05, 2017 | HP Wireless Optical Mouse
Dear Sir, My optical hp wireless mouse does not select a sentence or paragraph when I left click and drag on the sentence or paragraph to select it. The gray shade of the selection disappears once I...
wireless mouse 101 (no PC stated, no OS stated)
no mouse model stated.
so plug in a wired mouse for $3 and use that, until mr. wireless works?
the wireless needs many things to run right.
1: it's battery now dead. the manual to that covers this.
2: mouse drivers good . from HP if any HP mouse.
load the driver yet. Get them at HP, ever heard of theM>?
3: OS not corrupted, no OS stated, XP? vista, w7/8/10?
4: click CP control panel and set the mouse up like you want it.
there are many mouse controls ,and can be set wrong, simply.
Oct 19, 2017 | HP Wireless Optical Mouse
MOUSE IS HARD TO CONTROL VERY SHAKEY WIRELESS MOUSE THERE SEEMS TO NO DUST IN IT
Wireless mice are known to have trouble with certain wooden and metal surfaces that they can be used on, if not using a mouse-pad try one.
Secondly, if that doesn't work. Be sure that your mouse isn't set to be very fast in your mouse preferences under mouses in your control panel
Hope this help!
- Jason Cornelius
If it helps, be sure to throw me some thumbs up!
Dec 14, 2009 | HP Wireless Optical Mouse
HP Expansion Base - Wireless Keyboard & Mouse Set-Up
Any Radio Shack or Best Buy for sure and even Staples and the like will have wireless devices that should help you figure out how to hook up what you have. For that matter a new set might be so inexpensive as to save you the hassle.
Good luck,
JR
Feb 26, 2009 | HP xb3000 (417329-001) Docking Station
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
HP Wireless Optical Mouse Fading
Ref wireless mouse. Not sure if you have a solution yet but it seems there could be 2 sources to the problem. First a weak or decaying laser. Second, something you have introduced recently that could interfere with the wireless signal eg mobile phone, another wireless device, cordless phone, telephone wires close to receiver or maybe something else. Not sure what you do if the laser is failing other than clean the lens. You might have to get it checked or try a friends mouse to see if it is better. There s also a setting than can change the sensitivity of the mouse. Have you looked at those settings.
Dec 10, 2007 | HP Wireless Optical Mouse
HP WX412AA Mouse Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
