Question about Huffy Dual Electronic Basketball Game
Score board no working correctly
The basket on the right is scoring points even when baskets are not made. its scores when you hit the back board and it scores when you hit the rim. The basket on right is not keeping accurate scoring at all.
Why can't I get football scores in upper left corner?
The score might be hit away by the rising football.
Jan 04, 2016 | Televison & Video
How do you score in a game of darts?
This really depends on what style game you are playing. I will explain how to score with a game of 501. Each player starts the game with a score of 501. Players' scores are then deducted from the original number - with the goal being the first to reach 0. To get a 0 you will have to score a double on the last dart.
For any dart that lands in a non-ringed area you score the number shown on the outside of that segment. If a dart lands in the outer ring it counts as double the normal score and any dart landing in the inner ring is scored three times its normal value. The outer bull scores you 25 points and the inner bull scores you 50.
Jul 26, 2012 | Sport & Outdoor - Others
How is a dartboard setup and how is it scored?
Dartboards are divided into wedge shaped segments that are numbered non-sequentially 1 through 20. Each wedge is separated by wires which run to the center of the board. The center is made of 2 parts: the outer portion (which scores 25 points) and the inner portion (scoring 50 points). The wedges are subdivided by 2 narrow rings; the outer ring (double ring) scores as double the number indicated for that segment of the board, while the second ring (located halfway between the double ring and the bullseye scores as triple the number indicated for that segment of the dartboard.
Primary case scored behind clutch hub, oil grey colour off housing. any idea of the problem? thankyou. 1988 electraglide 1340
Grey color to me means water contamination..there is a seal there in mainshaft hole replace id replace the starter one 2 .. is scoring sounds like clutch wabble check shaft & clutch basket.. replace as neded...good luck...
Sep 08, 2011 | Harley Davidson FLHTC - FLHTCI Electra...
I dont know how to use a cheat engine 6.0
below is the tutorial for using cheat engine.
Ok....first all you need is:
Cheat Engine
and
Pinball 3D which comes with Windows XP
Ready?
First:
Open pinball 3d in your games directory.
Open cheat engine, dont start playing pinball yet.
Now we are going to try to find the address, that changes the scores of pinball 3D.
So... right now your score should be zero.
Go to cheat engine and clcik "Open Process" which is top-left computer icon.
Open the process named "pinball.exe"
Now since the score is still 0 we are going to find the adress by searching for an address with 0. So go to CE (Cheat Engine), and on value type 0, and leave the scan type to: Exact Value, and value type to:4 Bytes
Now click: First Scan, now... I got 1,995,549 addresses, you should get something similar. Don't worry we'll fix that.
Now go to Pinball 3D and start playing... once you hit something and you get points, immeadiatly click F3 or Pause the game.
Ok for me first thing I got was 30,000 points, so pause, write down what you got.
Now go to CE, and in value type your current score, for me 30,000
and click "Next Scan"
If you got more than 2 addresses, go back, get some more score, come back and re-next scan with your current score
*REMEMBER YOU NEED TO PAUSE YOUR GAME IN ORDER TO WORK*
Once you get 2 addresses on the left
double click on either one, becuase they are botk linked to each other, so if you change something to one the other one will change too.
Well now that you have it on the bottom sqaure, click once on it, and press enter, now type in your new value (or your new score icon_biggrin.gif) Max Score: is 999,999,999
After you put your score, go back to Pinball 3D, un-pause and, you'll notice that your score didn't change, well just make it hit something that gives you points, and VOILA!!!
*I suggest you dont put 999,999,999 for 2 reasons:
1 to get Game Over so you can sumbit your score you need to lose, to lose you have to play... and alwyas.. always you will get some points and it will reset to some low score. i suggest you put something like 999,900,000 believe me you can get 100,000 easily in pinball 3D
2nd: if you wanna impress someone but they dont you know your hacking the program, put something like 5million something like for example:
5,458,225 thats more believable than 999,999,999 they'll know you hacked it.
enjoy.
Apr 27, 2011 | Computers & Internet
NEED BOOK OF RULES FOR THE BOARD GAME CALLED SRABBLE
Each letter in a Scrabble game has a certain value within the game. Blank tiles, or tiles lacking an assigned letter, are worth 0 points. For each A, E, I, O, U, L, N, R, S and T used, the player receives one point. Two points are awarded for the letters D and G. Letters worth three points are B, C, M and P. Four-point letters are F, H, V, W and Y. K is the only letter worth five points, while J and X are the only eight-point letters. The letters worth the most within the game are Q and Z, worth 10 points each. With this in mind, spelling out HOUSE on the board in spaces that aren't worth extra earns the player eight points.
Extra-point Scoring
  • Certain squares on the Scrabble board give players extra points for placing a tile on that square. These squares are either pink, red, light blue or dark blue. Pink squares on the board are double word scores, giving a player double the value of a word if one letter from that word lands on the pink square. Placing HOUSE on the board with a double word score being covered would be worth 16 points. Letters falling on red squares receive triple word scores. HOUSE would be worth 24 points should one of the letters fall on a red square. The light and dark blue squares concern individual letter scores, with light blue doubling the amount and dark blue tripling the amount. If the H in HOUSE landed on a light blue square, it would be worth eight points rather than four. On a dark blue square, H would be worth 12 points.
Additional Extras
  • Should a word fall on two double-word squares or two triple-word squares, the scoring goes up even more. The word becomes worth four times the total letter amount if the squares covered are double word squares. If two triple-word squares are covered, the word becomes nine times the total letter amount. In one turn of game play, if two or more words are formed, each word is scored individually then totaled for that turn's value. If a player uses all seven tiles in one turn, a 50-point bonus is awarded.
Game-ending Scores
  • At the end of the game, players total up the number of tiles left in their hand. That number is subtracted from the score they've earned during game play. This becomes the final score. The player with the highest final score wins
Jun 18, 2010 | University Games Staying Alive Murder...
How do i score bowling in a dartboard game
how to play and keep score BOWLING
This dartboard adaptation of bowling
is a real challenge! It is a difficult game
in that you must be very accurate to rack
up a decent score. Player one starts the
game. You must select your “alley” by
either throwing dart or manually pressing
segment of choice. Once alley is selected,
you have 2 remaining darts to throw in
which to score points or “pins.” Each
specific segment in your “alley” is worth a
given pin total:
Segment Score
Double 9 pins
Outer Single 3 pins
Triple 10 pins
Inner Single 7 pins
There are several rules for this game as follows:
1. A perfect game score would be 200 in this version of bowling
2. You cannot hit the same singles segment twice within the same “frame” (round). The
second hit will count as zero points. Hint: Try to hit each single to reach 10 points in
the frame.
3. You can score 20 points per “frame” by hitting the triple segment twice.
4. Hitting the double segment with your second dart will only count as 10 points if you
scored a double on your first throw. Otherwise you will score a total of 9 points by
throwing a double with your second dart.
Mar 03, 2010 | Halex 64339 Match Play Electronic...
Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Sep 27, 2008 | Hotpoint Washing Machines
Huffy Dual Electronic Basketball Game Logo
22 people viewed this question
Top Huffy Toys Experts
ray gallant
Are you a Huffy Toy Expert? Answer questions, earn points and help others
