Question about Merkury Innovations Merkury M-hl852 Urban Beatz Tempo Stereo Headphones red & White
How to set up wireless headphone - Merkury Innovations Merkury M-hl852 Urban Beatz Tempo Stereo Headphones red & White
How to hook up wireless headphones
Haley, I have never done it, but it does not sound too hard. Read through the following links below to find out how to hook up wireless head phones.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.jabra.ca/q/how-wireless-headphones-work-how-to-connect
How to set up Wireless Headphones with the TV How Tos
How To Connect Wireless Headphones
Logitech Support
Apr 21, 2016 | Audio Players & Recorders
Conecting wireless headphones LC195L9A
How Wireless Headphones Work and How to Connect Them jabra_revo_wireless_image_1440x1440px_08.jpg?h=204&w=204Wireless headphones are headphones that connect to a device, such as a smartphone, stereo speaker, television, gaming console, computer, or other electronic devices without using a wire or cable. Wireless headphones work by transmitting audio signals through either radio or IR (infrared) signals, depending on the device.
From call centers to fitness centers, wireless headphones are used by millions of people every day for work and play. For example, wireless headphones are popular with gamers, since it frees you to move around without having to worry about a cord. People doing a workout at the gym or in front of their TV in the living room love the freedom of wireless headphones. They are also perfect for people who want to watch late-night television without disturbing others.
Wireless headphones work by connecting, or pairing, with the device you want to use, through a radio or infrared signal. Many devices use Bluetooth technology to make connecting easier for the user. Devices with Bluetooth technology can connect and exchange data over very short distances using radio transmissions.
A product with Bluetooth technology has a tiny computer chip inside that contains the Bluetooth radio, and software that makes connectivity between devices possible. So when Bluetooth-enabled products, such as a cell phone and headphones, are in close proximity to each other, they connect, or pair. This enables you to talk on the phone or listen to music without wires.
Connecting a wireless headphone differs depending on the device you are using, but it's easy once you know how. Here is a list of the most popular devices that people use with wireless headphones and how to connect them.
Connect Wireless Headphones to a TV
First, make sure that your base is plugged in and the headphone batteries are fully charged. Ensure that the headphones and television are in close proximity to one another. Turn the headset on. Go into setting on your TV and turn on Bluetooth. Find the headphones under Bluetooth devices in your TV and you should be able to hear the television.
Connect Wireless Headphones to an xBox 360
The xBox 360 supports two different types of wireless headphones, ones that have Bluetooth capability and ones that do not. The first method explains wireless headphones with Bluetooth capability.
Xbox 360: Headphones with Bluetooth
  1. Plug your wireless headset into the console to install the latest headphone drivers. You will need to be connected to xBox Live in order to do this step.
  2. Make sure that your headset is charged, which can be done by simply plugging it into the unit. If you charge your headset through the console, it will connect automatically most of the time. If they don't connect automatically, turn on your console first and switch the headset so that it is in xBox mode.
  3. Press the power button for two seconds until it flashes green. You should then hear a start-up sound, and when you hear that, press the connect button for two seconds.
  4. After you release that button, press and release the connect button on the console within 20 seconds or the connection will not be made. The green lights will flash three times to let you know the connection was a success.
XBOX 360: Headphones without Bluetooth Capability
  1. Make sure that your headphones are charged, which can be done by plugging them into the USB port of the console.
  2. Turn on the console and the headphones. After they are powered up, push and release the connect button on your console.
  3. Within 20 seconds, press the connect button on your wireless headphones for two seconds. You should now hear sound from your headphones.
Connect Wireless Headphones to the iPhone
Setting up your wireless headphones with Bluetooth technology is easy on the iPhone. Here's how:
  1. Find the "Settings" icon on your iPhone, which is normally on the home screen.
  2. Open and click on the "General" button.
  3. Then, hit the "Bluetooth" button and slide it over to turn the function on.
  4. Your iPhone should find the device once this is enabled and should show the device name on screen. When it does that, you will need to hit the "Pair" button in order for the devices to sync. You may need to enter a four digit password, which is provided with your wireless device.
  5. Once that is entered, hit "Connect" on your iPhone to complete the setup. Your headphones should now be working properly.
Connect Wireless Headphones to the PS3
  1. You will first need to register the headphones to the PS3 through the Bluetooth settings. Here's how:
  2. Go to the XMB home menu and select the "Settings" icon.
  3. From there, select the "Accessory Settings" icon, and from that menu, find the option that says "Manage Bluetooth Devices."
  4. If there is no current Bluetooth device registered on the PS3, there will be an option that says "The Bluetooth device has not been registered. Do you want to register?" You will need to highlight the "Yes" option and click the "X" button on your controller. If the pairing was successful, the device will show up on the screen.
  5. Next, you will see a screen that says "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, refer to the instructions supplied with the Bluetooth device."
  6. Click on "Start Scanning" on the screen with your "X" button so that the PS3 can start to scan. Also, you need to make sure your headphones are in pair mode so that the PS3 will recognize the device. If the pairing was successful, it will show you on the screen and you just need to hit the "X" button to continue.
  7. You will then be asked to enter the pass code or security key that was provided with your wireless device. Use the keyboard that is provided on the screen to enter the pass code. Once everything is entered properly, a message tells you that the device has been registered.
  8. Next, go back to the "Accessory Settings" menu to access the "Audio Device Settings" menu. Select the "Input Device" option by clicking "X" on the controller. When the new menu opens, look for the proper microphone input that corresponds with your device. Once you find the right one, click the "X" button.
  9. Select the "Output Device" option to select the headphones. Once you search through the options that the system recognizes, click "X" on your wireless headphones to select them. You should now be set up and ready to use the wireless headphones and microphone.
Connect Wireless Headphones to an iPod
  1. jabra_revo_wireless_image_1440x1440px_14.jpg?h=444&w=444Make sure that your wireless headphones have Bluetooth capability.
  2. Access the "Settings" icon on the home screen of your iPod. Select the "General" option once you are in that screen.
  3. You will then see an option that says "Bluetooth", which you can slide over to enable Bluetooth on the iPod.
  4. Be sure that your wireless device is in discovery mode so that the iPod can recognize it.
  5. Once you enable the Bluetooth on the iPod, it will list any devices that is recognizes. Simply click on your wireless device when the iPod shows it and click the "Connect" button. Your headphones should now be paired and working properly.
HOPE THAT HELP - GOOD LUCK.
Feb 01, 2015 | Sylvania LC195SL9 19 in. LCD TV
Where can I get replement headphones for my 2005 Town and Country
If you're talking about the wireless headphones, I have 2 sets of them that I will sell to you for $30 for both. They are in excellent condition. Send me your email address....Dave
Sep 01, 2014 | Plantronics Backbeat 903 Bluetooth...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Wireless headphones won't connect with tv
ENSURE THAT THE SETTING ON YOUR TV SET HAS BEEN SET. DOUBLE CHECK IF THE HEADPHONE IS COMPATIBLE WITH YOUR TV SET
Sep 12, 2012 | NexxTech High Quality 2.4ghz Wireless...
I have 2 pair of Sony MDR-RF925RK wireless headphones. They cannot be used at the same time for different audio sources (Computer + TV) as both headset pick up the same signal. Do I have to return one...
You don't necessarily need to buy a different brand of headphones. Check with Sony and see if they offer the same headphones with different frequencies.
I've had to do this with other wireless products in my own home.
Mar 20, 2011 | Sony (MDRRF925RK) Consumer Wireless...
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
Liquid Video Wireless Headphones
I got replacement ones at Best Buy. The don't have to be specifically LiquidVideo
Mar 31, 2007 | Liquid Video MVOHD701 Car DVD Player
Merkury Innovations Merkury M-hl852 Urban Beatz Tempo Stereo Headphones red & White Logo
61 people viewed this question
Top Merkury Innovations Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Merkury Innovations Audio Player and Recorder Expert? Answer questions, earn points and help others
