Question about Frigidaire ATF6000ES Front Load Washer
I also have grease marks on my clothing after a wash. My old washer did this same thing and it was a broken seal. We had to get a new washer. That was a top loader. This new one is a front loader and is only 8 months old. Could it be the same thing or is it the plumbing?
  • 26 Answers
Probably a broken seal. If you just brought it have a service man come out and look at it.
Posted on May 25, 2009
Good morning, I'm about to install a new gearcase into my Whirlpool direct drive washer. After removing the old gearcase I noticed some grease inside the drive tube top rubber seal. I don't know if...
no place to add and grease/oil
THE IMPORTANT THING THOSE IS TO OPEN THE VENT HOLE ON NEW TRANSMISSION AS STATED ON THE NEW PART BE SURE TO POKE A HOLE ON THERE
The grease you see now should be cleaned or it may permanetly stain your clothing...it was from oil leakage from the old trans/gearcase
Aug 26, 2011 | Washing Machines
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
MY GE WASHER PUTS WHAT LOOKS LIKE GREASE SPOTS ON MY CLOTHES.
sounds like the transmission seal has started to leak. yes the transmission, all washers have these and at a certian age and usage the seals will start to leak grease into the drum. if this is an older unit this is not uncommon.
1) you can try to replace the seal
2) or you can buy another washer
service repairs for this cost almost as much as a new washer
Aug 10, 2009 | GE WDSR2080D Top Load Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Detergent build up
try to wash clothes with pre-wash program
Feb 17, 2009 | Candy CN146 Front Load Washer
Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Apr 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing machine problems
Oil or grease due to failing seal on the drum shaft.
Jan 14, 2008 | Washing Machines
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Frigidaire ATF6000ES Front Load Washer Logo
202 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
