Question about HP Ipaq Bluetooth Stereo Headphones Fa303aaba Fa303 Over-thead
Faulty want to open
My 2006 ford fusion sel v6 is having cylinder misfiring problems the codes it reads out are p0171 p0304 p0305 p0306 and p0300
p0171 is fuel injection system too lean - bank 1
possible causes
- Intake air leaks - Faulty front heated oxygen sensor - Ignition misfiring - Faulty fuel injectors - Exhaust gas leaks - Incorrect fuel pressure - Lack of fuel - Faulty Mass Air Flow (MAF) sensor - Incorrect Positive Crankcase Ventilation (PCV) hose connection
p0304 is cylinder 4 misfire detected.
possible causes
Faulty spark plug 4 - Clogged or faulty fuel injector 4 - Faulty ignition coil 4 - Fuel injector 4 harness is open or shorted - Fuel injector 4 circuit poor electrical connection - Ignition coil 4 harness is open or shorted - Ignition coil 4 circuit poor electrical connection - Insufficient cylinder 4 compression - Incorrect fuel pressure - Intake air leak
p0305 is same as above but cylinder 5.
p0306 is same as above but cylinder 6.
p0300 is random misfire detected
possible cause
Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure
Oct 31, 2016 | 2006 Ford Fusion SEL
Codes 32 75 12 22 on a check engine light
first code it's P0320 Possible causes
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Ignition/Distributor engine speed sensor harness is open or shorted
- Ignition/Distributor engine speed sensor circuit poor electrical connection
- Low battery charge
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0320_ford.html#ixzz3DcwddSlp
2- P0750 Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 1 valve
- Shift solenoid 1 valve harness or connectors
- Shift solenoid 1 valve circuit is open or shorted
Read more: http://engine-codes.com/p0750_ford.html#ixzz3DcwoXS73
3- P0120 Possible causes
- Faulty Throttle Position Sensor
- Throttle Position Sensor circuit is open or shorted
- Throttle Position Sensor poor electrical connection
Read more: http://engine-codes.com/p0120.html#ixzz3Dcx3VCPs
4- P0220 Possible causes
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Read more: http://engine-codes.com/p0220.html#ixzz3DcxGUMl4
Sep 11, 2014 | 1991 Ford F150
Why is codes p2106 p0401 on?
P2106 THROTTLE ACTUATOR CONTROL SYSTEM,-PO401-EGR INSUFFICIENT FLOW
May 29, 2014 | 2005 Ford Explorer
2005 nissan frontier problem code 1757 and 1759
ObdII Code 1757 means the transmission oil could be burned or the oil pan has excessive dirt in it. There could be internal transmission damage. However, other things that throw that code include a faulty Governor Pressure Sensor, a Faulty Governor Pressure Solenoid, a Faulty Valve Body, an engine Control Module (ECM) 5 volt supply, a 5 volt supply circuit could be open, a 5 volt supply circuit could be open inside the transmission, or a - Faulty Engine Control Module (ECM).
On the other hand, a Code 1759 means a possible faulty Front Brake Solenoid Valve, or a front Brake Solenoid Valve harness is open or shorted, or a Front Brake Solenoid Valve circuit with a poor electrical connection.
Apr 15, 2014 | 2005 Nissan Pathfinder
P0452 ,P0305 aurora 3.5
P0452 means fuel tank pressure sensor circuit low pressure. Possible symptoms:
- Fuel Tank Pressure Sensor harness is open or shorted
- Fuel Tank Pressure Sensor circuit poor electrical connection
- Faulty Fuel Tank Pressure Sensor
The code 0305 means cylinder 5 misfire detected. Possible symptoms:
- Faulty spark plug 5
- Clogged or faulty fuel injector 5
- Faulty ignition coil 5
- Fuel injector 5 harness is open or shorted
- Fuel injector 5 circuit poor electrical connection
- Ignition coil 5 harness is open or shorted
- Ignition coil 5 circuit poor electrical connection
- Insufficient cylinder 5 compression
- Intake air leak
Read more: http://engine-codes.com/p0305_pontiac.html#ixzz2d8l8VHWe
Read more: http://engine-codes.com/p0452_pontiac.html#ixzz2d8kXRa8w
Aug 27, 2013 | 2001 Pontiac Grand Am SE
Get E3 when I press start
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is open .Repair
Test the sensor speed for open or faulty. +Reed swtich sensor. for open or faulty.
God bless yousee diagram and try to adjust.1_25_2013_4_44_15_pm.gif1_25_2013_4_44_34_pm.gif
Jan 25, 2013 | Exercise & Fitness
2000 gmc 1500 p0300
I think the P0107 is the root cause of the problem.
P0300 is a random engine misfire on all cylinders.
Possible causes - Faulty spark plug (s)
- Ignition coils poor electrical connection
- Clogged or faulty fuel injectors
- Injectors harness is open or shorted
- Injectors poor electrical connection
- Improper spark plugs
- Intake air leak
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input.
Possible causes - Manifold Absolute Pressure harness is open or shorted
- Manifold Absolute Pressure sensor poor electrical circuit connector
- Faulty Manifold Absolute Pressure sensor
- Faulty Powertrain Control Module (PCM) or Engine Control Module
(ECM)
Feb 02, 2012 | 2000 GMC New Sierra 1500
I have a 2001 Mitsubishi Galant and my son received 4 codes off of the programmer. The recent one is P0300, then the next 3 are P0441, P0335, P0455. Can you tell me what the codes stand for
A code P0300 may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • A code P0441 could mean one or more of the following has happened:
    • Bad vacuum switch
    • Broken or damaged EVAP line or canister
    • Open in PCM purge command circuit
    • Open or short in Voltage feed circuit to Purge Solenoid
    • Faulty purge solenoid
    • Restriction in EVAP solenoid, line or canister
    • Corrosion or resistance in purge connector
    • Bad PCM
    Defective computer
Mar 13, 2011 | Mitsubishi Galant Cars & Trucks
Mitsubishi 98 faulty fuel cap, leaking vent or purge solenoid, evap hose faulty, leak on fuel tank, PO455
Mitsubishi 2006 faulty fuel cap, leaking vent or purge solenoid, EVAP hose faulty or leak on fuel tank.... replace the fuel cap and a week later the light was back on...the code is P0442..what to do next
Aug 01, 2010 | 1998 Mitsubishi Eclipse
Error Code E580
Error Code E580 relates to these below:
• The stack tray lifter motor (M5) is
faulty.
• The stack tray paper height sensor
(S10) is faulty or the harness
connector is disconnected or has an
open circuit.
• The stack tray lifter motor clock
sensor (S9) is faulty, or the connector
is disconnected or has an open circuit.
• The stack tray lifter motor load is
faulty.
• The finisher controller PC is faulty.
Dec 07, 2007 | Canon imageRUNNER 400S Copier
HP Ipaq Bluetooth Stereo Headphones Fa303aaba Fa303 Over-thead Logo
93 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
