Question about Samsung / RF197ACRS
Water freezing under the vegtable drawers - Samsung / RF197ACRS
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
We have got Zanussi Fridge/Freeze, water from the fridge area keeps running under the vegtable's drawer area, which I need to wipe/clean constantly.
Check that the little drain hole at the back is not clogged it sounds like this is the case,its easy to clean try something soft like a straw to push in to clear, Normally I get a mouthful of hot water and squirt this down the straw,Works well for me...Good luck.
Apr 04, 2011 | Zanussi Microwave Ovens
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
Water is collecting below the vegtable drawers. Can you tell me how the drain is supposed to work?
Clean the defrost drain line on the back wall of the fresh food section.
May 07, 2009 | Refrigerators
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Vegtables freezing in refrigerator drawer
This could be due to frozen air passages...defrost the unit, food packed too close to the passages, possibly low on gas.  First, clean out your condenser radiator at the bottom of the unit...rear.  It is probably blocked.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water build up in the bottom of the refridgerator under the fruit and vegtable cripser draws. maytag model #MTB1954ARW
Water build up under the fresh food drawers is usually associated with an air intrusion from the exterior. Warm air intruding into the fresh food compartment creates excess condensation, which eventually accumulates on the bottom.
Some causes are:
1. Internal obstruction, not allowing door(s) to close tightly enough.
2. Deteriorated door seal, (torn, pinched, deformed, misaligned,).
3. Light not turning off when door closed,(faulty door switch, misaligned door, loose hinges allowing door to drop).
Make sure all drawer have nothing obstructing their closure, and door shelves have nothing extending beyond the support bars.
Other less obvious causes may be creating this issue also and are not normally addressable by the novice servicer.
Hope this helps find the cause.
May 25, 2008 | Refrigerators
Samsung / RF197ACRS Logo
27 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
