Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
Keypad doesn't light up.
The lock works fine except the keypad doesn't light up. The interior LED works fine as well. Any suggestions?
  • mogiz May 11, 2010
    I'm having same problem. Brand new, interior led works fine, but exterior keypad won't light up
    I'm having same problem. Brand new, interior works fine, but keypad won't light up
If this is a battery operated lock then the backlight doesn't stay on (otherwise it will wear the batteries out). To make the keys light up when you want to enter your code you have to push the lock button on the keypad first. If the keypad light has never come on then open the door and manually lock the interior lock then press the keypad lock button then the above instructions will work. This is the solution I got from Kwikset customer support and it worked for me. Hope this helps you.
Posted on Jun 10, 2010
  • 2 more comments
  • evangolie207
    evangolie207 Mar 02, 2013
    Well, this simple info did get my keypad light to work again!
  • evangolie207
    Now, does someone have a solution to the inside LED not lighting up?
  • MommaB
    MommaB May 15, 2013
    Finally, the right answer!!
  • Jjh Gg
    Jjh Gg Jun 16, 2017
    You da man/woman bc205. Spot on!
  • 4 Answers
You may have a kink in the tape inside or the connection fingers (tiny ones) may not all line up. Have a looksie
Posted on Oct 07, 2009
    New Friend:
Tried 1st answer and did not work so I tried the 2nd answer and sure enough one finger was bent. I got that fixed and it still didn't work so I tried the first answer again and it worked so it was both answers combined
Posted on Aug 17, 2015
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
My unit is not lit up. Impossible at night to see numbers for code
Oct 10, 2011 | Weiser Lock Powerbolt 1000 Lock
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
After locking my car, the interior lights dim and go out as usual and then come back on and the doors will keep locking themselves.
The problem is in the keypad assembly. It causes the interior lights to come on and off and can drain the battery. This also causes the doors to lock and unlock without driver input. The keypads on this model usually go out if someone is playing with it or trying to discover the unlock combination. If you don't need to use the keypad for entry or access to the trunk you can disconnect the keypad and you won't experience the above mentioned problems.
Mar 10, 2011 | 2000 Lincoln Continental
I have a 3/4 hp model 139.53990D from sears. My reomtes have quit opening the door. they will close it. The light on the control console blinks very lightly, not like when the lock is set. Door works...
The symptoms you give are exactly the way it is when the lock function is used. The wall control and the keypad will work but not the hand remotes. If holding the lock button for 3 seconds doesn't change it you should hold in the smart/learn button for 6 seconds. This will erase all remotes from memory and only the wall control will work. Now program it for the remotes and the keypad.
Jan 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
The back light is not working on our kwickset keypad smart controller.
When your door is locked, you must hit lock again before entering your code. After you hit lock the second time the LED back light will come on.
Dec 31, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Locking the keypad
In Settings/Personal/Buttons choose Fan "Lock" and mark "Disable all buttons except power button"
Sep 11, 2005 | HP iPAQ hw6515 Pocket PC
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
8,975 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
