Question about CBTL Coffee Bean and Tea Leaf" Milk Frother
Ld4100 red blue light flashing - CBTL Coffee Bean and Tea Leaf" Milk Frother
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Voyager pro / can't turn off, can't re pair, light flashes red blue red blue
Had the same problem. Light just flashed blue and red. I decided to put the headset on the charger while it was flashing and after about 30mins of being left on the charger it started working normally again. Hope this works for you.
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
CBTL Coffee Bean and Tea Leaf" Milk Frother Logo
43 people viewed this question
Top CBTL Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a CBTL Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
