Question about 2wire Computers & Internet
Budwieser red light will not connect - 2wire Computers & Internet
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
CEILING FAN MODEL AM-1
The red wire is the hot wire for your light so connect it to the black wire on your light. The white neutral wire should connect to your other white wires on fan power wires.
Sep 02, 2012 | Hunter (25417) Ceiling Fan
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
I am adding a light to a Hampton Bay fan. From the ceiling wiring I have a red and a green wire that are not connected. Is the red wire for the light and do I tie it in to the black wire to the fan for...
The green is a ground and the red is the hot wire for the light. One wire from the light kit is white and should be connected to the other white wire in the fan. The red wire should be the hot wire and gets connected to the black or blue (other wire) from the light kit. If you connect the two wires and the light does not come on, you need to find the other end of the red wire and make sure it is connected to a switch to give it power. The other end of the red wire is probably in the single gang box where the wall switch for the fan is located. Or you can tie the red wire for the light to the black wire for the fan and simply use the pull cord to cut on/off the light.
Jan 26, 2011 | Heating & Cooling
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lost internet connection, router has a red light on it but i cant connect
Just for you to be aware, a red light on the router means it failed.
Depending on where the red light is, that is where the connection failed, if the red light is on DSL, it means that there is a problem with the server (internet service provider) but if the red light is on INTERNET (authentication failure = router needs to be reconfigure) etc.... to better assist you contact your service provider.
Oct 02, 2010 | D-Link (DI-711) Router
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Red light flashes as i plug in the adapter
solid red light means ready to connect. If you hve a flashing red light that means you have a hardware ploblem. Try using adiffent USB. go to xbox 360 suport for more imfo.
Jan 29, 2009 | Microsoft Wireless Network Adapter Xbox...
Computers & Internet Logo
73 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
