Question about Vollrath Boxer 20 Qt Food Mixer 57620
Replace cord on boxer mixer model 57620
Need wire daigram for cord replacement
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Why is mixer not working?
Double check power at outlet or try another outlet with known power. Check the plug and cord connection. I recently had to replace my toaster cord because the cord at the plug had separated one of the wires. May be a switch or a safety device.
Jul 05, 2015 | Food Mixers
How do i replace the power cord on a sunbeam model 11c mixer
You will have to open the machine up and disconnect the old cord and install the new one.
Oct 14, 2014 | Sunbeam Classic Mixmaster Stand Mixer -...
How to replace power cord on kitchenaid k4-b?
Take the four screws off that separate the top of the mixer from the stand,they are just above the handle that locks the bowls up when mixing.once you get the top off you will see where the wires connect to,simply disconnect the wires,remember which colors go where,because when you put the new cord on you will need to know where each color goes,it pretty straight forward,once cord is screwed in,put top of mixer back together and the screws are evenly tight.plug it in and mix away,if there's no power orbit sparks unplug right away and check wires ,to make sure you got in right spot and they are tighten down all the way.
Jun 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
I have the 300 watt hand mixer and the retreactable cord no longer holdes when pluged in. It's been broken for some time. Is there a fix to this problem.
The prongs on the plug have worn, and the plug can be replaced (for less than $2 USD) from any
hardware store, just cut off the old plug, and wire the new plug onto the cord.
Remember to keep the cord's conductors correctly oriented: the conductor on the Bravetti Hand
Mixer that have the uncolored stripes (in the insulation) is the Neutral conductor, the other is the Hot conductor - assuming your abode is wired to standard US 120VAC.
Aug 08, 2011 | Bravetti EP552H Hand Mixer
How can I replace a damaged power cord on my KitchenAid stand mixer, Model #K45?
Firstly get a new cord. Then remove the trim plate and then the end cover. Remove the rubber grommet and then the three cables from the clips. Replace with new cord.
Feb 13, 2010 | KitchenAid K45SS Classic Stand Mixer
The cord has a short and I need to replace it
Hi, this is a very simple process. I don't know if the cord is a 2 prong or 3 with the ground, but it makes no difference. You should have screws around the perimeter of the mixer that you need to take loose to separate the half's. I am assuming the cord is built into the mixer, if not please correct me. The end of the cord will be connected to the on/off control, may it be a trigger type or slide or what ever it has. You will have either a black wire which is hot, connected to the switch so the switch can break the connection to turn the mixer on and off. The other wire may be white which is neutral connected to another wire in the mixer, you will see this. If it has a ground, 3 prong, it will be green and will show you where it connects. If it is just 2 prongs, the 2 wires may both be black and in this case you can connect them to either wire they are showing you. I don't believe the connections are soldered, they may be screw connections or wire nut connector's. If it would be easier for you, take the mixer with you to your hardware store such as Home Depot as they have many different cords to choose from, and you will get help in the electrical section to make sure you have all you need. Just take your time and put the wires back in the same way as the old cord was wired. If the cord is a detachable cord, take it with you and match it with one that has the same connections and 120 volts. You do not have to buy a Black and Decker cord to do this. There are many cords that will do the job just as good if not better. Keep me posted if you need my help.
Sincerely,
Shastalaker7
Feb 12, 2010 | Black & Decker Ergo EHM90 Hand Mixer
Power cord for GE hand held mixer
I have a gold mixer also, My wife loves it. The cord went
and was unfixable. I found one on this website abtecparts.com.
The cord was $5.99 plus shipping. Good Luck
Pat
Mar 18, 2009 | Food Mixers
Disassembling the mixer
does the plug run through the base or the back of the unit?
Jun 10, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Vollrath Boxer 20 Qt Food Mixer 57620 Logo
35 people viewed this question
Top Vollrath Food Mixers Experts
eyecam
Are you a Vollrath Food Mixer Expert? Answer questions, earn points and help others
