Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
Temperture control switch not working
Have to manually move control to cut in and out
  • Whirlpool Master
  • 4,655 Answers
If the temp control works manually then that tells me that the tube that is connected to the thermostat is not telling the refrigerator compressor and fans to come on by sensing the temp change. The part number for the thermostat is 2198202 if the model number is correct above your post. If ED25PQXF is not the model number then we need to possibly change that number. Let me know, Thanks Sea Breeze
Posted on May 20, 2009
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Over heating problems
The radiator fan is probably not working. The fan is controlled by a temp switch, located on the intake manifold, just below the thermostat housing. murf427
Aug 04, 2012 | 2002 Jeep Grand Cherokee
Where is the temperture control system
some model has not display temperature control system.
You must see your instruction manual for indicate how to control the temperature. if you do not have download www,fitness.manualsonline. com or www.retrevo.com or www.manualsfactory.com
God bless you
May 09, 2012 | 2005 Chrysler 300 Hemi
The cut off system for the water level no longer works and it overflows if you dont manually move the knob forward
If the appliance works when you move the knob forward it means that the timer work is working and that the inlet valve is not stuck open. In that case the problem is the water level switch that does not cut off when water level reaches the limit. The water level switch is a pressure switch.
Replace the water level switch. before replacing the switch you can check its connectors and try cleaning the rubber hose attached to the switch. The pressure switch is located in the control assembly and is part nr.10 in diagram below:
Here the part for the model indicated in title:SWITCH PRESSURE (Pressure Switch)
Aug 20, 2011 | GE WDSR2080D Top Load Washer
The heater put out very little heat. also the temperture gauge moves very little. is this a bad thermostat. or could it be a bad heat control value.
If the Temperature gauge is moving less than before, its your Thermostat. If the Engine Temperature is the same, then your heat control valve is not opening or a duct flap(called a door) is not moving under the dash.
Having a Bad thermostat will affect how controls on the engine work and when they work.
Oct 07, 2010 | 1992 Mercury Grand Marquis
The switches on my steering wheel that control
Look for a iluminated fuse,or inst.lps,fuse,try moving the dial,or knob to brighten the instrument lighting.
Jan 19, 2010 | 2002 Buick LeSabre
Auxiallry fans on radiator dont seem to come on. how do they work
Hi, They are controled by a thermo-fan switch, when coolant reaches a certain temperture fan switch turns on radiator fans and brings temperture back down. Thermo-Fan switch is located bottom of radiator.
Dec 03, 2008 | 1990 Subaru Legacy
Light and temperture control indicators don't work
The refrigerator was moved to a new location.  The temperature setting was on 41 degrees.  After the move the temperature indicator does not indicate any temp.  How do I reset the temp.  and turn on the indicator?
Oct 22, 2008 | Refrigerators
Refrigerators Logo
119 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
