Question about Apex Digital Televison & Video
Can't switch spdif setting on apex flat screen
Trying to set up home theater system. Can't switch spdif setting from pcm to raw after connecting digital optical coaxial cable, the selection is grayed out. what do I do?
  • 4 Answers
SOURCE: HDMI Connection to Ooptical Output
Talked with Sharp, it's a issue with hdmi and optical out, best fix for it that I'm currently using is a 3-way toslink splitter, cost a little of nothing and work perfectly, you just turn the dial to the signal you want to play off of. Clicky
Posted on Jan 24, 2008
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
  • 77 Answers
SOURCE: SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Posted on Feb 25, 2009
How do I connect my flat screen tv to my Phillips MX3900 system
This is an older home theater package and only has component video out for HD and RCA or SPDIF optical out for audio. You'll need to locate the component video input on the back of your flat panel and connect it to the component output of the Phillips unit. Component cables have 3 RCA cable (Red, Blue, Green) for HD. You can use a RED/WHITE RCA cable for audio but if you have a SPDIF Optical cable you should use that for better sound. The TV should have that as an input also. You will need to go into the Menu for the TV and select component video and SPDIF optical if you went that route for audio.
Dec 03, 2014 | Philips MX3900 System
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
Bought the A99HR Nikkai DVD player and recently the sound does not work anymore. Picture and everything else is working alright.
I had the same problem when I switched over to a HDMI cable. It's the sound settings. I had to switch my audio setup in the settings menu to PCM for HDMI and also choose only SPDIF / RAW or PCM.
Jun 13, 2011 | Audio Players & Recorders
How do you hook up a home theater system without an out put
Hi, on this TV there is a SPDIF port that they say to hook-up to your home theater system. Depending on your amp receiver if it has an spdif port then thats the way to go. if not then you could always run audio cables from your cable/satellite box to your amp receiver, and the same for your dvd player and any other device. Hope i was of some help : )
Feb 12, 2011 | Apex Digital LD4088 LCD TV
My ampex 5.1 channel home theater speaker system switches off after approx. 30minutes of play and has an in built FM reciever that doesn't work i.e doesn't get reception
Possible there are DRY SOLDER JOINTS within the main board and so when the set heats up there is a connection loss which makes the set switch off. Remove panel and try to work the set while cooling with a fan , touch to see if any section like power-amps gets hot. If so observe with a magnifier and solder.
Check the external antennae connection to the system, if this seems ok then the RF end/ signal processor is faulty which might need a trace with technical help.
Jan 24, 2011 | Coby 5.1 Channel Home Theater Speaker...
How can i get the system to work with my tv
if you have it connected with the HDMI cable to your tv, use the ARC on the receiver to hear audio out.
Jul 18, 2010 | Panasonic SCBT230 Theater System
Hooking my flat screen tv to my home theater
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Dec 02, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
