Question about Vivitar DVR 548 HD Digital Camcorder DVR548HD-BLACK
My camcorder I press the bottom of power and not respond
I try put and put out the batteries a nothing.
MAC G3 QUICKSILVER WON'T START UP AT ALL, WHAT CAN I DO TO TRY AND FIX IT?
Disconnect all the device.
remove the ram
remove the battery
keep it aside for an hour
then put them back , don't connect the power cable , press and hold the power button for 20 seconds then connect power cord.
good luck
Jun 10, 2014 | Apple Power Mac G4 Dual Mac Desktop
Sylvania HD1Z DV-5000 Camcorder won't power up
Sounds like the battery is faulty, or is not charging properly. Can you remove the battery and try it on another (heavy load) device? At least check with a voltmeter and put a (say) torch/car bulb across the contacts
Jan 31, 2014 | Sylvania HD1Z Camcorder
Screen has hp logo and says press the ESC key for startup menu, but is not responding
Try a hard reset. Disconnect the power adapter (charger). Remove the battery. Now press few times the power button. Yes, with no power the laptop will not start but the idea is to drain any residual power left inside your laptop. Put the battery back and try again.
Dec 15, 2013 | HP ProBook 4530s Notebook
When I turn on my handycam the Clock Set screen comes up and whatever I press, nothing responds. I cannot get this screen to go away so I can play tapes and record
Hi,every camcorder has a special built-in battery for its clock in addition to the external camcorder battery which works independently.You have to replace it...
Would you please locate that small battery on the main body of camcorder hiding with small cover lid possibly you need to get in with a tiny screw to open it..and replace that battery and re adjust the clock once ,than no more the Clock Set screen comes up..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 20, 2011 | Video Cameras
I tried to restore factory settings on my Toshiba Saetellite L500D and it will not configure. Kept trying to configure - got to first screen where it asks you to press enter to commence system set up and...
Try to do a complete power drain by doing the following:
1.Remove the power cable.
2.Remove the battery.
3.Press and hold the power button for at least 10-15 sec to drain all remaining power stored in the board.
After this, try plugging the power cable without the battery and turn on the computer. Check if the computer will respond. Put the battery back.
Nov 12, 2010 | Toshiba Computers & Internet
Will not turn on or start up..Sony Handycam DCR-DVD300 DVD
Try resetting the Camcorder to the factory settings by pressing the reset button. If the issue persists, try power resetting the camcorder. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 second(or turn the Power switch to ON position for 30 seconds) and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 27, 2010 | Sony Handycam DCR-DVD300 DVD Camcorder
Dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Feb 17, 2009 | Dell Inspiron 5160 Notebook
Aiptek won't turn on
Try taking the battery out and putting it back in. I don't know why, but it worked for me. Good luck!
Jun 21, 2008 | Aiptek IS-DV2 Camcorder
Camcorder not working
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 27, 2007 | Sony Handycam DCR-TRV250E Digital...
Vivitar DVR 548 HD Digital Camcorder DVR548HD-BLACK Logo
21 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
