Question about Frigidaire Electric Dryer
Frigidaire dryer has no power - Frigidaire Electric Dryer
  • 153 Answers
Check outlet
Posted on Feb 28, 2014
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
Why does my FERB7800DS0 Frigidaire dryer has no heat
Good Afternoon Friend,
I understand your Frigidaire dryer, model# FERB7800DS0, is not heating up. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Why wont my frigidaire dryer shut off when done
Good Afternoon Arlene,
I understand your Frigidaire dryer will not shut off when the time is done. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Electric Dryer
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Where is fuse on frigidaire aeq7000ego
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire front load dryer won't turn on at all
check the main power and terminal block make sure there is power and no problems with the terminal block.
also a bad thermal fuse can cause a problem with the power check the thermal fuse and make sure they have continuity.the last thing to look at is the main control board these can cost up 150.00 dollars depending on where you get it.Bottm line yes i would say it is worth fixing
Jul 27, 2010 | Frigidaire Electric Dryer
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 11, 2009 | Frigidaire Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire  Electric Dryer Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
