Question about Acer PD322 DLP Projector
Reset PD322 My PD322 recognises my laptop on startup of the laptop but then loses the connection. Pressing the MENU on the projector does not have any effect.
How do you reset lamp timer
This is usually accessed from the projector's main menu. Use your remote by pressing 'MENU'. Navigate around each menu option until you find something referring to 'RESET'. (ie: reset lamp, reset, reset to zero)
No remote? - You'd have to use the onboard projector buttons.
-GWOOD
Jul 15, 2014 | Vidikron Office Equipment & Supplies
I have a acer projector ph110, it telling me to replace the globe. Change the globe but can't get into the menu screen to reset globe hours. Try pressing the menu botton but it stll have the warning...
Hi, I had the same problem all you have to do is connect something to the projector like a laptop or dvd player so it has a signal. Once the picture comes up of what you are projecting from the laptop or dvd player you can enter the menu and reset the lamp hours. Hope this works for you if not please let me know.
Mar 30, 2011 | Acer PH110 Multimedia Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
Filter timer needs to be reset
In the advanced menu go to option, then highlight filter time and hold down on the right side of the menu button until the filter time reset menu comes up. When that comes up choose reset by pressing the up arrow on the menu button.
Nov 10, 2009 | Hitachi Performa CP-RS55 Multimedia...
The projector can't find the source, which is my laptop. If it does find it, it lasts one, maybe two seconds, and then it's lost it. We've tried two different laptops, and it cannot hold the connection for...
Maybe the cable connected to the projector is bad?
If you shut down the laptop and plug the projector in on 'PC' mode, does the projector recognise the video output?
Jun 09, 2009 | Dell 2400MP DLP Projector
When i connect my dell latitude d630 laptop to projector it did not work. Pl. suggest any suitable solution. Regds safi
after connecting the projector just press function key and F4 . After pressing these key the projector connected automatically
Jun 02, 2009 | Computers & Internet
View sonic projector
Go to menu and choose option. Then choose lamp time or filter time, depending which one you want to reset and keep pressing reset-button for 3 seconds
Jul 23, 2008 | ViewSonic PJ551 Multimedia Projector
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Office Equipment & Supplies
Acer PD322 DLP Projector Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
