Question about Sony KDL40CX520 40" Multi-System LCD TV
High volume on sony tv hd channels
When I change from normal channels to hd ones,the volume goes sky high,nearly bursts my eardrums
  • Geraldine Rynn Dec 31, 2013
    it is sony smart tv,connected to upc box,via hdmi cable, adjusting volumes on tv or upc system doesnt help
  • 362 Answers
SOURCE: Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 04, 2009
SOURCE: Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Posted on Mar 07, 2009
SkyGuy08
  • 27 Answers
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
railfan20
  • 20 Answers
SOURCE: volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Posted on Jun 01, 2009
  • 325 Answers
SOURCE: Can not get sky + hd hand control to set volume on
Pleae follow the steps below. I hope it is a SONY like the picture indicates:
On the sky remote press the following buttons in this order.
TV
RED + SELECT ( hold these down until it flashes twice)
TV
0000
SELECT.
Job done. Please Leave a thumbs up when you get around to following these steps.
Thanks
Little Dish Fitter
Posted on Sep 28, 2009
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Change address on component for Harmony One
Has anyone found a code for the above ViewSonic N3246W LCD TV?. I have just got a Sky+HD box and would like to operate the TV volume with the Sky remote.
Thank you in anticipation.
Mar 31, 2010 | Logitech Harmony One Advanced Universal...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Volume not working on sky remote
Mar 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Digital TV
right hdtv stands for high definitian tv witch basically means if you buy a hd dvd player or blueray then you can watch the films in really high quality alot better than normal dvd. The same if you had cable tv or sky you pay a fee for an hd converter then this lets you watch certain channels in high def. So it basically means that your telly is capable of using all the new hd equipment thats coming out like the playstation 3 can play high def dvd's as long as you buy the hd lead as you need this due to the fact that it sends more data to the telly their for giving alot better sound quality and alot better piture quality when watching hd dvd's.
At the moment their are only a few tv channels that are using hd at the moment but this will soon change.
So to watch hd dvd youll need an hd dvd player and to watch hd tv you need to contact your cable or sky people and ask them what you need to do to watch hd programmes. they will then upgrade your box and should send you an hd lead to plug into your telly from the sky or cable box.
Hope this is helpfull and easy to understand.
Hd is well worth having as the quality is amazing you wont believe it till you try it i was shocked as the detail and quality is mind blowing its like watching real life, it really is that good.
Let me know if you need further assistance ok
May 14, 2008 | Sylvania 6427TE 27" TV
Sony KDL40CX520 40" Multi-System LCD TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
