Question about Garden
Deck belt pops off idler pulley
The mower is a Troy-Bilt Pony, model no. 13AN77TG766, made in 2006, with a 17.5 HP B&S engine and 42 inch deck.  The manual is available at .
When mowing today, I found the deck belt kept coming out from around the right-hand Idler Pulley (near where the "PTO" cable is (incorrectly) shown attaching to the Deck Idler Bracket in Figure 17 on page 19; also in Figure 21 on page 23).  There seems to be a vertical misalignment between the Engine Pulley and the Idler Pulley, so that the belt, coming off the Engine Pulley horizontally, runs into the top edge of the Idler Pulley (which isn't _meant_ to be horizontal, is it?  'Cos it isn't).
So you see that tab on the Deck Idler Bracket in Figure 17 next to the right-hand Idler Pulley?  The belt squeezes between the rim of the Idler Pulley and the tab, getting a big groove worn into it, a puff of smoke (can't see it, but I can smell it), and no more power to the blades.
I probably put that belt back around the Idler Pulley about ten times today before I gave up and changed the belt.  The other belt gave exactly the same thing.
  • dah31 Jul 19, 2009
    Short: Grab a 3/4-inch deep-well socket and tighten the nuts on the front lift rod nearly all the way down.
    Long:
    Well, since then, I've replaced the Belt Covers (parts 47 on page 40 of [URLhttp://manuals.mtdproducts.com/mtd/DocGe...]) and the nut that holds on the left-hand Idler Pulley (incorrectly labelled as part 19 on page 40; perhaps part 18 (the description looks right)). When I lost the nut, the deck belt got shredded (shrod?), so I replaced that, too.
    That worked quite well up to about 96% of the lawn done, when I found a shredded (shrodden?) Belt (the rear drive belt, part 31 on page 34). Page 22 says, "Several components must be removed and special tools (i.e. air/impact wrench) in order to change the tractor's drive belts. See an authorized Troybilt Service Dealer to have your drive belts replaced." Not having those tools nor any instructions, I asked a neighbour to take me and the mower up to the local dealer.
    But a couple of days later, I had a look at the diagrams and decided to order the belt and try and install it myself. Turned out it was pretty straightforward, and I only needed hand tools. It took me a while to work it out, but I reckon I could easily change that belt in well under half an hour now. (And it was only US$16 on eBay (for the official MTD part), too.)
    Once I had everything back together, I tried it out. It threw the belt off the idler again.
    The next day, I tightened the nuts (parts 21 and 22 on page 40) on the Deck Rod, Front Adjustable (part 41), almost all the way down. This left the front of the deck (page 16) probably higher than the rear (I haven't checked), but it also loosened the deck belt. It would appear that the part of the deck belt between the Engine Pulley and the right-hand Idler Pulley needs to be loose (-ish) (and it /will/ be the loosest part of the deck belt, since it's ahead of the driving pulley): the slack allows the belt to approach the Idler Pulley approximately horizontally, so there's no way it can get pinched and thrown.
    At least, that's my interpretation. I'm now up to 200% mown at height setting no. 3 with no problems. Hooray! Next time, I might try no. 2.
  • 376 Answers
SOURCE: I need a diagram to adjust/level the Deck
The adjustment is on the left rear deck hanger. Loosen the 1/2 lock bolt in the center of the large nut, then turn the large nut with a adjustable wrench or socket, if you have one that big, clockwise or counterclockwise to raise or lower that side to equal the right side height.
Posted on Jun 05, 2009
wadembly
  • 475 Answers
SOURCE: engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Posted on Jun 08, 2009
  • 77 Answers
SOURCE: belt comes off the deck on my Troy-bilt model number 13an77tg766
If your going through belts that often you better order some spindle bearings and have them rebuilt,excess play in your deck spindles can cause you a lot of money repacing belts.
Posted on Aug 09, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
rycgl
  • 1545 Answers
SOURCE: troy-bilt model 13AN77TG766 wont go
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
Posted on May 21, 2011
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Belt diagram
One end hooks to the idler pulley arm, the other hooks in a slot in the deck.
Jul 20, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
    Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
    with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
    Nov 07, 2009 | Garden
    How to adjust belt tension 42" raftsman lawn tractor cutting deck
    Note: This is about a different mower, but it might be similar enough to yours.  If not, please disregard.  Thanks!
    I had a similar issue with our mower, a 2006 Troy-Bilt Pony model 13AN77TG766 (17.5 HP, 42 inch deck): when I pushed the handle down to engage the blades, it took a good ten seconds or so to start the blades turning; even then, they didn't have enough power to cut the grass.  And on any height setting lower than 5, they wouldn't turn at all.
    The cause was on page 19 of the manual <URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf>: Figure 17 shows the "PTO" cable attaching to a hole on the edge of the deck idler bracket, but it was shipped from the factory attached to a hole in the middle of the deck idler bracket, about 3 cm (1 in.) closer to the front end of the machine.  I reattached the cable to the original hole, and the belt is now good and tight; the blades engage as soon as I push the handle down.
    Now, today, I'm having problems with the belt popping off the right-hand idler (hopefully just needs the deck stabiliser rod adjusting).
    Always remember to remove the spark plug wire before you go near the blades; and watch for hot, sharp, and/or pinching surfaces.
    May 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Ineed the diagram for a 42 inch deck troy bilt
    We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
    Apr 26, 2009 | Garden
    Garden Logo
    813 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
