Question about Panasonic Tc P60u50 - 60 Class 60.1 Viewable Plasma Tv
Hi i have a panasonic tc p60u50. and yesterday my son hit the tv and made a small crack in the screen. you cant even feel the crack. is the tv bad? or could it be a su sd board. im getting 7 flash whe
Tv want power on. red power led blinks 7 times.
  • 3 Answers
Did he hit the tv in the area of the power switch, this gives the symptoms you are describing, if you damage the power switch, its a common fault.
Posted on Jan 02, 2014
  • Dah Gurlz Wirihana
    Dah Gurlz Wirihana Mar 13, 2015
    Hi there same thing happnd to y panasonic viera bt the crack is at the top corner and whenn turning tv on it lights up green then blinks 7 times?would u know whats wrong with it?
SOURCE: red flashing led on my panasonic viera
Replace battery. Battery is defective
Posted on Aug 31, 2009
  • 131 Answers
SOURCE: my son just through one of his toys at our new
Hello; I have run a TV repair business for 34 years now. That whole plasma screen is under a very high vacuum just like a light bulb or neon sign tube. If there is a crack anywhere on it, air from the room will quickly rush in, making it impossible to light up. This Plasma panel will cost more than the set sold for. Time to buy another set and maybe protect it with a sheet of Plexiglass cut to your screen size. John
P. S. cracked screens are never covered by warranty, but you might check your homeowners ins. or credit card if you used one to buy the set. Also if that crack is in the plastic cabinet and not the glass screen your set my still be repairable.
Posted on Nov 22, 2010
vinceisaac
  • 2432 Answers
SOURCE: hi mate i have a
hi good day welcome to fixya
lets verify first to narrow down where the problem came from, now when the indicator is flashing then doesn't steady to green that is mean their is something error detected by the main board that is why won't turn on. at this point you will need to apply trouble shooting so first you need to open the back cover of the tv unit to access the internal part make sure you have the proper tools and device. now turn the tv on then while the indicator is flashing you need to check the output voltage of power supply if all present the 5v stand by,5v switch,12v and 24v. then check the PS_ON voltage from the main board going to power supply if not available their is a problem with the processor. then at the same time you need to have a INV_ON voltage going to inverter ballast if also no voltage around 3.3v then it was confirmed you have bad processor. check also bad component at inverter ballast a shorted component will cause the main board to shut off. hope this will help just let me know if it works thanks for consulting the fixya.
Posted on Sep 02, 2011
maatmartin7
  • 1210 Answers
SOURCE: Hi i have problem with my Panasonic TH-42PV8EY- 7
I have not repaired this model. My first thought are bad capacitors in the power supply board. If you do have the exact board to replace. I would certainly do so. Numbers check and you say they are the exact same, should be an easy fix. If this board came out of another TV of the same model, you must remember, it will have the same longevity as the board that does not work. I would compare the boards, and look for bad capacitors on the board that does not work of course. You may check the capacitors with an ESR meter (about 50 to 75 bucks). The purchase and price of one of these will pay for itself. You can fix other electronics. Thanks for asking Alan. I'll be here if you have more questions.
Posted on Oct 21, 2011
gopakumarg43
  • 74251 Answers
SOURCE: I need help changed power supply board and ss board and still no picture it is a model TC-42PX14 panasonic the red light still blinks seven times. At wit s end isn't much, can you help me.t
Check this link and select the site named 'Electro-help' You can get more details about the fault to your TV, with 7 blinks of standby light. Check this link and select the site named above.
Posted on Jul 28, 2012
I have a Sony kdl-46es700 flap screen LCD TV; The picture is black, red indicator light blinks 7 times every three seconds. Have already replace the power board. How do I resolve this problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 30, 2016 | Sony BRAVIA KDL-46EX700 46" LED TV...
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Feb 20, 2009 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Panasonic Tc P60u50 - 60 Class 60.1 Viewable Plasma Tv Logo
253 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
