Question about Frigidaire Refrigerators
Lost power to frigidaire fghb2844lf7 - Frigidaire Refrigerators
Frigidaire phs69ehs freezer high temp beep
Let's begin by finding what the PHS69EHS User Guide has to say=> HERE
Appliance 911
Sep 29, 2015 | Frigidaire Refrigerators
My frigidaire stove made a loud pop while oven was on and then lost power....stove top elements working stove clock not working tested fuse, and changed it still not working
Thank you for your post, friend!
I understand that your Frigidaire range made a loud pop while in operation and lost power. I noticed you stated that the stove top is working and you have changed out the control board but the oven is not working. It could be a possibility that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Feb 24, 2015 | Frigidaire Kitchen Ranges
Frigidaire gallery all of sudden lost all power, no digital display. power to wall outlet is ok. refrigerator does not work
I understand that you are having difficulty with your Frigidaire refrigerator not receiving power. It sounds like a possible problem within your control panel or wiring harness. I would recommend reaching out to a technician for proper diagnosis and repair to be completed. This can help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Sep 14, 2014 | Frigidaire Refrigerators
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
I have a frigidaire freezer ffu21cwaw1 we lost power for 4 hours now the freezer sees to be defrosting. the power light is on and it is set to coldest but everything is defrosting.It is not a frost free...
There probably was a power surge from the power failure which has taken out your control board or the starter relay switch for the compressor.
May 05, 2009 | Frigidaire Freezers
No power
you will need to replace the 20amp fuse above the control. also obviously fix the door switch. which can all be accesible through the control panel
Jan 04, 2009 | Frigidaire GLMB209D Microwave Oven
Refrigerators Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
