Question about Electrical Supplies
Hook up yellow blue wire
Does the blue and yellow wire gotogether
3 Suggested Answers
james3751
  • 614 Answers
SOURCE: I am replacing a White
Yes you did correct. Tape of f blue wire. On your thermostat you should have el/gas turn top el and fan should work Russ
Posted on Mar 23, 2010
clifford224
  • 1975 Answers
SOURCE: what is the blue and yellow wire on the wire harness for the kenwood kdc-138?
According to any wiring diagrams I have looked at for the radio in your vehicle (both the premium and base systems), the only wire that I see that could get pretty much anyone confused unless they know is a dimmer wire coming from your headlamp switch. The only reason I cannot be 100 percent sure is because according to the wiring diagrams it is a black and yellow wire but I don't see any other wire with yellow that could cause a question. To be sure you can always check at the connector on the headlamp switch and check for continuity but if I were a betting man I would put my money on this. I went on and gave you the wiring diagram for the base system (without an amp). Not sure how well you can see anything due to a size limit on pictures but I hope I was able to help.
Posted on Dec 02, 2012
Blue power antenna wire is causing radion to stay on all the time what should I do
The 3rd wire is coming from the bypass switch. I have the solid blue wire from the unit the blue and white from the jeep and the bypass wire all hooked into one. Is there another wire I could hook the Blue wire too I had two yellow wires coming from the radio one is with the yellow wire from the car the other is capped off could I unhook the blue from the blue and white/bypass and hook it to the other yellow possably?
Apr 15, 2014 | Pyle PLTS78DUB Car Video Player
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Where to connect blue wire on a 16 seer Westinghouse condenser unit. It has 3 low voltage wires a black a yellow and a blue.
If you have 3 wires hooked up to the indoor unit, you need to read the terminals to which they
are hooked to. On the outdoor unit you need to see on the electrical print where the low voltage
wires should go. However it is uncommon to have three wires, 2 wires is common..
For instance, on the furnace if Black is connected to Y terminal then black at the condenser
would go to one side of the contactor. If Yellow is hooked to C terminal at furnace, the
at outdoor unit Yellow wire would go to other side of contactor. If Blue is not Hooked to
anything, tape it off.
Sep 01, 2011 | Heating & Cooling
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
Blowing fuses
you may have the rem wire hooked up to the yellow 12v battery wire located on your harness. try yellow to yellow and if your rem is not working correctly when is hooked blue to blue put in on the red ignition wire located on your harness. should solve the problem. or return it
Mar 02, 2008 | AudioControl KVT-911DVD Car Video Player
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
