Question about Miele Novotronic Premier 500 Front Load Washer
Heating element replacement miele w806 - Miele Novotronic Premier 500 Front Load Washer
2 Suggested Answers
  • 6277 Answers
SOURCE: Miele Washing Machine W 2365. How
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 30, 2011
How to change a drum bearing on a w806
Go on you tube and type it in. I have found many there that help me step by step video
Dec 07, 2014 | Miele Washing Machines
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Miele Softtronic T8423C only blows cold air..
If you are fairly sure that the power is reaching the clothes dryer, and the clothes drum is spinning, unplug the dryer first. Then using a continuity checker check the heating element. very often if the element needs replacing you will notice a break in the coil. Just like a light bulb, the heating element will eventually need to be replaced. The coil is the only source of heat, although it has components that operate it .
Dec 05, 2013 | Miele Dryers
MILE W-833
Please check this link to get some tips to replace the heating element
click on Heating coil replacing
click for spares : miele element
Jan 14, 2013 | Washing Machines
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
My miele dishwaher is not heating the water thus not wahsing the dishes properly
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele G661 Dishwasher heating element
Loosen element-retaining bolt plus clips in dishwash chamber. Upend machine and take base off (held by four crosshead screws). Disconnect spade connectors from end of element and gently tap/push old rubber block through. Element will drop out with retaining rubber.
Hautebrian.
Mar 06, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele Novotronic Premier 500 Front Load Washer Logo
29 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
