Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a Great White GWB50 Runs only at one speed Can only turn it off with toggle switch. Variable speed doesn't work. Do I need a circuit board. This happened after I replaced the mount and reattached the wire to the battery. There was an aroma coming from under the cover and a resistor was very hot. If I need a board where do I get one? They are no longer manufactured.
I have one too. Although it could be the mother board - if it runs its the potentiometer. You can get one from Iboats or Mie Reel Repair the number is AP16802. If its the mother board they are switching to digital. I havent had to go there yet. Tight lines to ya. From South Texas Riviera.
Posted on Jul 17, 2009
Toro blower-vaccuum stop working
Replace the variable speed control with a toggle switch. Cut the 2 power wires that go to the big rotary knob and wire to a toggle switch that you can install by drilling a hole near where the power cable enters. Works great and full power all the time.
May 25, 2014 | Toro Electric Ultra Blower/Vac 12 Amp
On my Vitamix 5000 the variable speed control does not work
It will probably just need the pot replacing, take note of where the wires go. I see someone else here is doing the same job and wants to know where to put them back. Take a photo first saves a lot of grief. The pot is the rotary resistance switch behind the knob.
Mar 24, 2014 | Vitamix 5000 Work Top Blender
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
Amana heat pump/AEPF variable spd air handler system works great, but air flow at the higher speed is just too noisy (ducts are not very wide). Is there a way to limit how fast the air handler / blower...
Open the airhandler -should be a speed selector on the main board. If not -checkt he installation/set-up manual. May be some dip switches you can turn on or off to modify blower speed.
Jan 26, 2011 | Goodman CLQ36AR49 Air Conditioner
DW788 blows the fuse immediatly. I purchased it about a year ago and have finally gotten around to using it, so the warranty has expired. I took it apart and saw that a circuit trace below one of the...
can you bypass the motor speed controller(circuit board) and hook the line cord directly to the motor? then if it runs at full speed and doesn't over-heat ,you know its still good
Feb 11, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Variable speed switch FERM ROUTER
the variable switch had 5 connection points on it, i bridged the connection on the 2 outer points with insulated wire,pretty much to see what would happen, this worked,
as this will be a router fitted to a table i will at some point remove the wire and
attach a 5way rotary switch, used for guitar electrics and mount it
into a electrical switch casing,
Oct 10, 2008 | Freud Tools & Hardware - Others
Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Nov 30, 2007 | Hampton Bay 24002 Ceiling Fan
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
645 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
