Question about Irons
Braun optiglide-jet iron has no power. iron has no light on it when plugged in. no sign of electical power on iron.
3 Suggested Answers
SOURCE: Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Posted on Apr 08, 2009
  • 5 Answers
SOURCE: Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Posted on Jun 26, 2011
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
How do I fix my iron because it is not turning on
1. If there is sign of power (e.g. light is on), the heating element may be broken.
2. If there is no sign of power, check the power point (socket), iron power plug, cable and the power on switch. If everything is fine, you need to get it repaired.
Jun 09, 2014 | Irons
The iron turns itself off while I'm ironing. Whats the problem?
I noticed the same problem my friend. The problem with mine was that the wire was having some kind of partial contact at the end inside the iron. The wire was twisted and tangled. I will advice You to
  1. Unscrew the iron from the compartment at the back of the iron,
  2. Then You force up the control of the iron,
  3. You will see 2 screws side by side, unscrew them open to release the lower part of the iron,
  4. Tail the wire to part that it is connected to in the iron,
  5. Then you unscrew the screws that hold the wire and disconnect it from the iron, then you Cut the rough edge of the wire or you can replace the wire completely,
  6. Reverse the process to reassemble the iron back together.
Also another cause might be that the connection to the power socket is loose and disconnects itself while you are ironing. In that case, it is the socket you are to replace.
Some irons are also made that way, that once it gets too hot and is not being controlled, the power will cut off its power supply by itself.
That should do the job for you. Hope this information was helpful.
Jan 12, 2011 | Braun Irons
Is posible to clean iron sole plate by steel
use the green no scratch pads,they are not so abrasive.
Sep 09, 2009 | Braun Irons
Broun iron (model SI6285) quit working
Small appliances nowadays aren't really designed to be taken apart. Most likely there wont be replacement parts, you are probably better off just buying a new one.
Jun 06, 2009 | Braun SI6285 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Oct 14, 2008 | Braun SI6285 Iron
Red light flashing
Feb 07, 2008 | Braun SI6225 Iron
Irons Logo
18 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
