Question about Globe Toys
Overwound snow globe
I have an overwound music snow globe
How do you fix an overwound music box?
The spring hub ratchet has to be released while firmly holding the spring hub. Once free the spring pressure must be released slowly. It shouldn't be necessary to release all the spring pressure.
If the spring hub is not held firmly it will fully unwind violently, often breaking the spring.
Jan 06, 2018 | Audio Players & Recorders
I bought a snow globe and I can't get it to charge nor turn on. My pc won't even recognize it. What is the deal and do I just need to send it back? It is a Unison Digi-Snowglobe with DPFMate...
I also have this same snow globe bought it in Pigeon Forge, TN this Christmas...today I decided to pull it out and use it and guess what?? It wont come on and my computer doesnt reckognize it either...Did you ever get yours working?? If so how?? Thanks
Dec 18, 2012 | Sakar Cameras
My 6 foot inflatable snow globe won't blow the snow inside,the fans and motor are working just fine it just wont blow the snow it just sits in the bottom...
Maybe the problem is condensation. The globe gets all fogged up and the snow pellets start sticking to the plastic and it just looks like a mess. Temperature might be less of a concern where you are, but it is something to consider. I had briefly thought of putting something like a hair dryer in line with the main fan to keep the inside temperature up. But it turned out to be more of a problem than I wanted to deal with. Good luck though!
Dec 20, 2010 | Gemmy Inflatable Polar Bear on Motorcycle
The glass that holds the water and snow has broken,can this be repaired
If you have all the pieces, it can be repaired. the tricky part is getting it refilled and sealed. If the globe is glass, you can use any cyanoacrylate glue (crazy or super). If it is synthetic, it is important to get an adhesive that is compatible with the material of the globe.
Oct 11, 2010 | Globe AUBURN TIGERS MUSICAL GLOBE -...
My gemmy inflatable snowglobes ( 2) are not blowing snow this year. The fans work fine- the globes inflate- but the snow just sits in the bottom of the globe. If I shake the globes the snow works for a few...
I am having the same problem the globe is inflated and the characters are rotating but no snow its all bunched up on the bottom and doesnt blow all the way up if you get an answer from gemmy its a miracle. if you solve it please contact me at marriageishell@aol.com thanks.
Dec 12, 2009 | Gemmy Toys
How do you fix a broken snow globe fan?
look closely at the fan blade, it probably got a little bent and is rubbing. You can bend it a bit and free it.
Sep 27, 2009 | Kitchen Appliances - Others
I have a disney snow globe that has a rusted music box and the fluid is low in the glode. How should it be repaired?
Hi
i hope my advice will help you. What I would do is the first thing is take it to a ceremic workshop they have all clock parts music box parts phone parts as when people make these they sell them the parts and show them how to put them in if that dosent work or you are not near a ceremic workshop try a clock or a watch maker they will take a look and might be able to repair it. If not I would then go out look for a music box find the company that made it or the company that makes snow globes just type it into google manafactures of snow globes or who makes snow globes and send it off to them but call them first and ask them if they could fix it for you they will usually say yes either drop it into the repairs area or send it to them but you will have to call first.
Hope that helps
Aug 07, 2009 | Disney Princesses Beauty and the Beast...
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Toys Logo
137 people viewed this question
Top Globe Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Globe Toy Expert? Answer questions, earn points and help others
