Question about 1996 Geo Prizm Voltage Regulator Standard
Need 30v fuel pump relay and cant find for my 1996 geo prizm
    New Friend:
    Problem Solver:
  • 9 Answers
Where is the starter relay located on a 1996 GEO PRIZM?
Junction Block #1--Above Left Kick Panel--Info On Inside Of Cover.
Feb 26, 2015 | 1996 Geo Prizm
If my car wont start do I need a fuel pump 96 Geo Prizm
Could be battery, ignition or fuel? Have it checked by a garage!
Nov 16, 2014 | 1996 Geo Prizm
Wheres the inertia switch located on a 1996 geo prizm
why not post symptoms.?
what engine, 1.6L or 1.8l or? 4a or 7a toy engine.
there is no such switch.
its really Toyota Corolla.
my guess, it dont start? or dont crank
and you didnt check fuses first.
and the CEL dont glow key on
or you failed notice the immobolizer is active?
the fuel pump relay has 2 coils,
one for PCM control
and the crank signal.
there is no inertial switch
i looked at alldata.com at a 1.8L.
post sympotoms and i can work it to the cause
it only takes a $10 voltmeter, to fix most problems.
Jan 14, 2014 | 1996 Geo Prizm
Four wires to fuel pump on geo prizm 1996
2 for pump and 2 for sender?
post symptoms, can answer with tests that find actual problems.
low or no fuel pressure, cranking, ?
triple posted?
Jan 14, 2014 | 1997 Geo Prizm
I have a condition in a 1996 geo prizm 1.6L where the car starts but will not run more than 2 seconds. At that time, the fuel pump relay is open. The diagnosis is either a bad distributor or a bad ECM. I...
The Prism is actually a Corolla, so you can use info for either model. You should have a main or EFI relay that powers the computer and the fuel pump relay. The engine computer powers the pump relay if it sees oil pressure or RPM.
Have you checked the EFI relay and the pump relay for power, and will the engine run if you bypass either relay ?
Aug 01, 2013 | 1996 Geo Prizm
95 geo prizm wont start
wont crank or will not start.? 2 unique things. no crank always results in , no start (unless you push start the car)
hot wiring the fuel pump relay or any relay in the EFI system , invites
blowing the ECU to kingdom come, bad to the bone that.
I fixed them for 50 years. (electronics controls, so know it !)
you do know its really a toyota right?
what ENGINE? each works different.
my prizm text dump.
89-02
joint venture, GM/toyota with 3 engine used.
1.8L or 1.6L
toy engine, 4aFE, 7AFE or 4AG
open hood look
or use the GM RPO tag
or Use the VIN to find motor used.
for docs?
ebay
search
Geo Prizm factory service manual, Duh?
http://www.ebay.com/sch/i.html;jsessionid=D19D723C2EDB4A9FE12E7C01C0677129?_sacat=0&_nkw=geo+prizm+shop+manual&_nkwusc=geo+prizm+shop+manaul&_rdc=1
does car start with test fuel and run, until the fuel runs out.
do you have fuel pressure, while reading the FSM , way of doing it.
some cars only make fuel pressure, cranking and runing.
other make pressure, for 3 seconds key on, and cranking and running only, and all cars drop pump and injections when ECU sees spark die.
that is why stating which Toyota engine YOU HAVE, helps with diagnosis. and please stop hot wiring your car and learn to use a voltmeter. Ive seen $3000 ECU blown up do to bad mechanics.
Feb 18, 2013 | Geo Prizm Cars & Trucks
I need to find where the fuel pump is on my 1996 Geo Prizm and how to replace it. My manual doesnt mention it.
The fuel pump is located in the gas tank at the top of the tank. In order to change it you will need to lower the gas tank, remove all fuel lines and electrical lines and then there will be a locking ring holding the pump housing in place. Once you remove that instalation is the opposite.
Jul 20, 2010 | 1996 Geo Prizm
I need location of a 1995 Geo Prizm 1.8 fuel pump relay
I think it is under your rear seat cushion. Remove the rear seat cushion, you'll see the gas tank cover.
Jun 06, 2009 | 1995 Geo Prizm
1996 Geo Prizm Voltage Regulator Standard Logo
60 people viewed this question
Top Standard Voltage Regulator Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Standard Voltage Regulator Vehicle Part and Accessory Expert? Answer questions, earn points and help others
