Question about Garden
Snowblower problems newspaper sucked in and jammed auger
    Top Expert:
  • 3,698 Answers
You must remove the jam, even if you have to burn it out. .
Posted on Jul 06, 2014
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
Not sure how to reroute auger cable on craftsman snowblower
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
Feb 25, 2011 | Garden
I lose power and stall when i engage clutch to spin snowthrowing blades on my mtd 24" two stage snowblower. any way to fix?
You probably have a small rock or stick jammed in the smaller throwing auger. Carefully rotate the small auger backwards using a stick/board and tapping with a light hammer till the jamming object pops out. Be careful not to place your hands or fingers in even if it is not running. Worst case scenario the worm gear that rotates the larger auger is broken and jammed and needs replacement. If both augers move freely then you will have to remove the cover under the motor and inspect the belt drive mechanism.
Feb 21, 2011 | Mtd Products Yard Machines 158CC Tiller
I have trs22 john deere snowblower the the impeller turns but the auger does not turn . i think the key is sheard off in the augers transfer case . any one have a detailed diagram or a pdf file for the...
Go to weingartz web page and you will find the diagram and parts you need. I have a TRS22 with the same problem. You will need a worm gear, gasket/gear case, and a shaft key. I need to order the same parts. take appart the auger first you might need more parts
Jan 22, 2011 | John Deere Garden
I have a Sears snow blower. It is not throwing even a light snow. On engaging auger both sides spin slowly. I observed one side of the auger stops spinning when proceeding into snow pile. What may be the...
many Sears/Craftsman snowblowers have a shear bolt on the auger shaft or one on each side. This bolt is designed to break under a specific amount of force to prevent damage to the gear box or drive assembly if the blades encounter an immovable object or something becomes jammed (even a newspaper buried in the snow can cause this). They likely broke at some point during use in the past and you did not realize this, or they were not properly installed when the blower was new. If you check the auger shaft and find one or 2 holes that look like something should be there, then you found the most likely problem. If you reply with the model I can tell you exactly where to look and the part # or if you realize the bolts are missing you can contact that parts dept at Sears with your model and they can provide replacement bolts. Can be a pain with small things but a lot less expensive than a new gearbox.
Jan 13, 2011 | Craftsman Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
