Question about Honda 8 HP Engine
Honda water pump
I need the rpm to a honda 8hp water pump
Normally all the water pumps coupled with portable gas powered engine have 3000 - 3600 rpm
Posted on May 25, 2009
Intertherm furnace has no flame
It has an ignition control problem. Check the ignition transformer, relay, and the fuse.
Oct 28, 2012 | AO Smith Intertherm Furnace Motor 1/8hp...
We have a Intertherm Furnace Model # MGHA-056ABCFC-01 Serial # MGH9205-01793 115va 60hz 1ph 5.9amps 1/8hp rpm 1050 We need to find a blower motor and a blower wheel for our furnace. Can you help...
Phone book, refrigeration distributors, call and give unit make model # serial # 1ph 1050rpm 1/8hp and frame type of motor. Usually a belly band. Though any good parts house can get all needed info off of make model serial. You might need to call a few since many will not sell to you if you are not licensed.
Feb 26, 2011 | Heating & Cooling
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
May 20, 2009 | Honda 8 HP Engine
Drum on my concrete mixer is turning to fast
Hi
At an engine lower and higher rpm is because of the governor sensitivity sistem.An arm attaches to the shaft(inside the crankcase)with a clamp-bolt/nut.This arm are provided with a series of holes.To decrease sensitivity hook the spring into a hole lower than its original position.If needed you can make some extra adjustment holes.Hope this help you.
best regards savumihai71
Feb 01, 2009 | Honda 8 HP Engine
Honda 8 HP Engine Logo
114 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
