Question about General Electric DVLR223EGWW Dryer
Ge dryer shuts off by it self - General Electric DVLR223EGWW Dryer
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Why won't my GE electric dryer shut off? My GE
The model number you submitted is not valid. Long dry times and dryer not shutting off is either an element problem, an air flow problem. Lets begin with a good model number so we can see your unit as you do...
Waiting to hear from you,Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
Apr 20, 2012 | GE Dryers
My GE DVLR223ee0ww electrical dryer shut off after while
blow lint out of motor with compressed air.... vacuum will not work well here
Aug 14, 2009 | GE DVLR223 Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Electric Dryer runs/heats but takes double the time to dry than normal.
The temp is between 153 deg and 189 deg and yes there is a tech mode.
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Self clean oven won't come on after I cleaned it
It turned out that the lever for locking the oven wasn't pushed all the way after I cleaned it. We just keep playing with it and finally the oven came on.
Feb 10, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer shuts off
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Dec 30, 2007 | GE DBSR453EBWW Electric Dryer
GE dryer shut off prematurely and now won't start
I'm having the same problem with my GE dryer. I think that it may the safety thermostat receaching maximum temperature and shutting the dryer down.
I'm currently researching this problem now.
Dec 05, 2007 | Zanussi TC7102W Electric Dryer
Alternative cleaning for a self cleaning gas oven
easyoff makes a oven clean that is for selfcleaning ovens. just make sure you get the one that says for self cleaning oven and youll be fine
Nov 24, 2007 | GE DBSR453EBWW Electric Dryer
General Electric DVLR223EGWW Dryer Logo
16 people viewed this question
Top General Electric Dryers Experts
Tim Whalen
Ned Halaweh
Ned Halaweh
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
