Question about Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook
Internal HDD HARD ERROR!
How do i set up boot sequence
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
  1. Turn on (or restart) your computer.
  2. When the DELL logo appears, press <F2> immediately. If you wait too long and the Windows logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
  3. Look for Boot Order or boot sequence. You will see a list of boot devices. Whatever you want as 1st device needs to be selected in 1st or move them to TOP. It depends on your BIOS version. But this is very close to what you are looking for. Good luck, If you still cant find it then Message me. I will guide you through it.
  4. http://www.solano.edu/technology/data/D610/setup.htm
Posted on Dec 30, 2013
3 Suggested Answers
  • 8 Answers
SOURCE: "no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Posted on Jan 02, 2009
SOURCE: Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Posted on Aug 24, 2009
Hello I want to boot Latitude D600 by external HDD (usb port) without internall HDD there are no selection for USB Boot in his BIOS help me please thank
If the USB port is not available in the BIOS start up boot sequence then it is not possible to boot up from an USB port on this notebook model.
In this case the USB port will only be activated when Windows starts up from the internal hard disk and the USB driver is running.
Aug 01, 2011 | Dell Latitude D600 (D6005C) PC Notebook
Windows XP Pro will not boot up after installing Goflex external hard drive. I have disabled Legacy USB and reset boot drive order to my drive as first.
Hi oysjerry,
I see that you are experiencing a no boot issue after you installed your Goflex external HDD. before doing the options below, you can try booting into windows but do no connect your external Hard Drive on the system.
  • Keep on tapping f12 upon powering the system to get into the Boot menu screen then select you hard drive in the machine then press enter to boot to it.
  • If it boots into you internal hard drive after doing the Boot menu option then you do the last option provided.
  • Try changing the BIOS setting, check the Boot sequence if boot to other devices is the first boot priority then change it to your internal hard drive in the machine.
this should fix you concern,
if still this does not boot into windows
Apr 06, 2011 | Computers & Internet
My computer keeps trying to boot from another source
You would have to go into your BIOS by hitting the F2 key as it is turning on. Then go in, and under Advance settings, make sure that the only place that it boots from is the Hard Drive. Make that the primary.
If it still has an error coming up, then it might be a file system issue with the OS.
Apr 04, 2011 | Computers & Internet
Had a external hd pluged in and had shut the laptop up and later when I upened it back up to use it, it would not boot and said it had no bootable disk
remove the external hd before turning bakc the system on, it might be trying to boot up to the ext hard drive if the internal hard drive is not the primary boot device on your computer. go to the BIOS set up of your system then change the boot sequence make hdd as the primary boot device so you can use the ext hard drive even if after reboot.
Jul 21, 2010 | Acer Aspire One PC Notebook
UNDI initialize failed no media detected what should i do
Hi if your still having this problem then I have GREAT NEWS!! I have found a solution. Go into your bios screen at startup and enable your hard drive. I just found this solutions. In the boot sequence screen in the bios, apparently my internal hdd (hard drive) had been disable as a boot option. In order for me to enable it I had to press the space bar and made it second in the boot sequence next to the CD/DVD drive. Hope this helps!!
Feb 05, 2010 | Computers & Internet
In win set up
Hi!
You need to change the boot "boot from cd" to Boot from HDD"
You do that in the bios
So start the installation again, and when your pc starts to boot, get in to the bios and change the boot sequence to HDD
Good luck
Nic
Mar 04, 2009 | ASUS P4XP-X Motherboard
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Error message on my broadcom
PXE errors (Also known as Pixie errors) occurs when the system bios setup is configured to attempt to boot to the network card (an option used in some networks to load system images)
You can boot to the system setup (F2 at Dell screen) and make sure the HDD is 1st in the boot sequence and *** if there is a setting for the network card to turn off PXE (Usually they the following options (ON, OFF, ON W/PXE, select the ON option)
If the system is failing to boot to the hard drive at all, this can be a sympton of a failing hard disk drive. You can try and confirm this by booting to the HDD diagnostic on the F12 on time boot menu or boot to the Dell Resource CD and run diags from it. If the HDD fails diagnostics, it definitely needs to be replaced. If the diags pass, it is no guarantee that the drive is good though, just an indication that no fault was found.
Dec 05, 2008 | Dell Inspiron 1501 Notebook
HP Compaq Presario V6000T
what you need to do, is go into the Bios. usually F2 at setup.
Or esc or delete. you have to press a few times at bootup.
Once in the bios screen, find the page where you can change the boot sequence. it,s probably set to boot from HDD( hard disk ) set it to boot from CD/DVD first then FDD Or HDD second.
when you save and exit, it will boot from the dvd drive, this will give you access, to use the cd drive first.
then re-install your operating system.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
