Question about EliteGroup P4M800PRO-M Motherboard
Power swith order
Power switch order
  • wcbzero May 11, 2010
    What motherboard do you have?
    Brigadier General:
  • 10,406 Answers
It does not matter -- pressing the "power" button on the front of the computer closes the circuit, and the motherboard boots itself.
Posted on May 22, 2009
Power windows work from driver switch. New switch. No power to individual power window switches. Could it be a fuse ?
could be a fuse but more than likely it's the window lock switch being defective or needing cleaned, find a swith assembly at a bone yard.
Sep 14, 2015 | Vehicle Parts & Accessories
2002 thunderbird window won't go up or down replace swith still wont work fuse are ok does the switch get power
The master switch connector does have circuits that have power on them. The Master switch is not directly connected to the window motors. The switch sends a signal to the Front Electronic Module and the module controls operation of the motor on the driver side. The passenger door window motor is controlled by a different module
Nov 28, 2012 | 2002 Ford Thunderbird
THE POWER SWITCH ON THE FRONT OF MY GX5 IS GOING BAD, AMP IS LOSING POWER, STARTS WORKING AGAIN WHEN I FLIP THE SWITH ON AND OFF.
A lot of the rocker switches fail due to starting surge of these amps. You can try squirting a little CRC226 into the back if it has holes. You can get this product at Home Depot in the electrical dept. Use ONLY this product. Blue can about $2.70
If that doesn't fix it, then replacement of the switch is in order.
Mar 26, 2011 | QSC GX5 Stereo Power Amplifier
Motherboard no power
In this order:
check PSU is working ( fans run in the psu), test with another psu installed,
See of there is a green LED lit on the mobo
Check capacitors are not bulging or leaking and there are no signs of burned circuit traces on mobo
remove ram and try booting see if you get power to the cpu fan
try bypassing the PW switch and touching the PW terminals on the fpanel header to eliminate swith problem.
If that fails, suspect dead mobo
Jan 11, 2011 | EliteGroup ECS P4M900T-M2 Socket 775...
IN ORDER TO GET MY REDDY HEATER TO FIRE I HAVE ROCK THE ON OFF SWITH SEVERAL TIMES OR THE WIRES ON THE SWITCH COULD I HAVEA BAD SWITCH
Hello
Its either a bad switch or a very loose connection.
Try striping the wires back and reconnecting to the switch.
Mar 30, 2010 | Heating & Cooling
Re: wiring the FV-08VKS1
The black and white in the fan box are the main power and neutral for normal (low speed) of the fan. The two reds are the signal wires. It is basically a switch loop. You will actually need a total of 4 conductors (plus a ground) in order to run the high and low speed of the fan. The four conductors consist of 1) power from one switch to power up the fan, 2) neutral, 3) signal going to second switch, 4) signal going back to fan from second switch in order to run high speed. Without four conductors you can still run the high speed only by tying the two red wires in the fan together. This would be like always having the second swith in the on position. Hope this helps.
Jan 05, 2009 | Panasonic FV-08VKS1 WhisperGreen Ceiling...
EliteGroup P4M800PRO-M Motherboard Logo
71 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
