Flavel wfa 100w
How do i open the front filter- the plastic handle is broken
4 Suggested Answers
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
How do you open the bonnet of a Toyota corolla verso when the bonnet release is broken
If the handle is broken but the cable is ok use a pair of pliers, otherwise the front plastic grill may need to be forced to give you access to the main catch.
Jul 28, 2014 | Cars & Trucks
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
I have a 1997 F-250 HD. Driver door latch cable is broken at the handle end. I have a replacement cable, but need help figuring out how to remove the broken cable without breaking the plastic rod...
Door Handle/Latch Assembly NOTE: Due to the conversion from single 90-degree rod end shape to double 90-degree rod end shape, it may be necessary to remove more parts than the instructions indicate. This action will allow more maneuverability of the rod and ease the removal process.
Handle, Outside Door, Front Removal
  1. Remove the front door trim panel (23942) and front door trim shield (237A04) from the front door (20124). Refer to Section 01-05 .
  1. Disconnect the front door latch actuating rod (22152) from the handle link connector.
  1. Remove one nut and screw.
  1. Remove handle and pads from door.
Some rods are double 90 degree rods, they require the handle or lach to be free when the rod is attached.
Some have plastic clips that slide onto the rod. they pop off sideways.
May 06, 2011 | Ford F-250 Cars & Trucks
HI WE HAVE A CAYENNE 2003 - THE FRONT PASSENGER DOOR WILL NOT OPEN FROM THE OUTSIDE - IS OK TO OPEN FROM INSIDE - HANDLE DID 'SQUEAK' A COUPLE OF DAYS BEFORE STOPPING WORKING
remove door trim most likely plastic clip holding rod connecting to handle has broken. if not check other ebd of rod at lock mechanism
Mar 10, 2011 | Porsche Cayenne Cars & Trucks
Passenger front door does not open on a 2001 Cadillac Deville, but opens from outside
Your inside handle connects to the release mechanism with a rod.It's a steel rod about 3/16" diam. that will be connected to either the handle and not the release,or the release and not the handle.There's also a chance on a car that age that the connector on the handle has broken off because of years of use.
Carefully remove the inner door panel,look hard for hidden screws,then there's a plastic liner and sound insulation to remove,then you can get at the mechanics inside the door.The problem will be obvious,and not hard to reconnect if nothing is broken.
Good luck,let me know.
Bob
Aug 10, 2010 | 2001 Cadillac DeVille
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Mar 21, 2009 | 1991 Honda Accord
Broken passenger door handle
Same problem. I have a 2000 Suzuki Esteem GL. A year ago the driver's door handle broke. Heard a sound and then it was loose. Could not open it from outside. Had to open front passenger door, open the driver's door from inside and then go out again to enter from the driver's door. FRUSTRATING. My mechanic had to take the door apart to fix it. Just a week ago, my front passenger door died on me. Can't open it from outside nor inside. The door won't open. This is such a stupid problem that costs lots to repair. Never will buy a Suzuki again. Had too many problems with it (had to fix gas tank, doors that won't open, front axle...).
Feb 05, 2009 | 2000 Suzuki Esteem
Door handles (exterior)
This won't solve the problem once the latch is broken, but can help keep you from breaking your door latch on cold frosty days.
Shortly after buying my 99 Park Ave I noticed that the rear door handle on the driver's side was black, instead of painted gold to match the rest of the car. I presume that the previous owner had the problem mentioned above. To avoid breaking the flimsy plastic handles when my doors are frozen shut (which is often during the winter in upstate New York!), I use the remote to unlock the doors, then I open the rear door first. By opening the rear door first you can grab the edge of the door at the wheel well, while pulling gently on the latch. By applying most of the force to the edge of the door at the wheel well you can avoid breaking the door latch.
While the rear door is open you can repeat this process to open the front door, grabbing the edge of the door in the crack created by the open rear door, and lifting gently on the front door handle. (Just make sure the rear door isn't closed in the process or you will crush your fingers!) This approach has worked many times during the last two winters that I have had my Park Ave. Hope it helps others!
Dec 27, 2008 | 1999 Buick Park Avenue
Broken front door
Jan 29, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
