Question about Roland Music
How do I hook my RA2100W to my tv - Roland Music
Get a hum out of the speakers with or without music
This s a ground issue or your driver board has a bad component on it which can be replaced with a new one if you can find it. Look for burn marks.
Nov 28, 2016 | The Music
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
I need a operator manual for a lonestar sk-104 karaoke manchine
I have the same one. and I have had another model also.they are almost the same.If I am correct it is a cassette karaoke player.They take a special cassette that says lonestar super K.these players and tapes were from the 1992-1994.when you hook to the tv, the tv needs to be on channel 3 or 4.the back of the machine should have a switch with 3 &4.make sure both are on the same.on newer tv you may have to figure out the input & output.some say video some say line 1 line 2 etc.my machine uses a cable cord from tv to machine.any tape will play in them ,but only the special ones will put words on the tv. if you use the special tape when you put it in the machine only one side plays.it tells you on the tape.also only one side of the duel cassette compartment will put words on screen.my sk104 is side B.Hope this helps.if you still cant get on screen words,it could be that part of the machine just doesn't work anymore.that is what happened to my other one.
Dec 15, 2012 | Music
I need owner manual for Disney HM950KC karaoke machine
i am trying to connect this to my stereo, the volume is not loud enough, so i bought a split cable, connected to one of my outputs on my stereo receiver. it works but very deep, so i bought a thicker split cable and will try, but not sure how to hook up the video part. a staight wire to the back of my tv? will that work? also i cant find the right kareoke videos, each time I buy one, computer graphics come up but no words, any direction, send to ldeleon@reddyraw.com please
Sep 30, 2012 | Disney Hannah Montana Karaoke System with...
I cannot hook up my casio to a mac
Only new models will work with MAC.
Older models work only on PCs. But there mmay be 3rd party drivers for the MAC. I found one for my WK8000 by searching using Google.
Feb 06, 2012 | Casio Music
GPX Karaoke Machine with AM/FM radio and cassette, Manufactured 1/2001 Model C1550 do not know how to hook up to TV/VCR ?
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
Sep 21, 2011 | Digital Products International Karaoke...
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Alesis sr16: How do you hook it up??
Come from the main outputs, probably labeled L/mono and R and connect those to your mixer for your audio system on either stereo mix input OR two two inputs that are panned opposite.. DO NOT connect this to a consumer type stereo system as you may blow the speakers or amp. Consumer stuff just isn't able to take output from music equipment such as this UNLESS the volume is kept very low.
May 23, 2010 | Alesis Sr 16 Stereo Drum Machine
Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Feb 18, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
35 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
