Question about Leupold Optics
Leupold gilmore Which way is it supports to sit with dot dial right on top.is that plumb up and down?
DELITEING NUMBERS FROM MY COOLPAD SMARTPHONE
Touch "all contacts', select the one you want to delete and when it dials- hang up. Now go back and it will be a favorite. Press the 3 dots in the upper right corner of that contact box. You will bring it up in another box. Press the icon that looks like a head and shoulders. The next box will have the 3 dots in the top right again. Press the dots and a menu drops down with 'delete contact' included. Press delete and then ok.
Jan 26, 2017 | Cell Phones
To move the zero right which way do I turn the dial left or right? I have got conflicting advice and just want to make sure.
There should be an arrow indicating direction on the windage adjustment turret (normally the right side) of the scope. If the arrow is marked left, turn the adjustment knob the other way to move the zero right. To move the bullet point of impact right, move the adjustment knob (dial) right.
Nov 23, 2014 | Leupold Optics
Can't get seam former out
To remove the seam former (stitch pattern cam).
- Move your stitch selection dial so the white dot on the dial lines up with the red dot on the body of the machine. Then you pull the cam out.
It can be difficult to remove if the cam has been sitting in the machne for a long time.
Mar 13, 2014 | Husqvarna Viking 1
Can't get seamformer out
Mar 13, 2014 | Husqvarna Sewing Machines
I have a 3 X 9 Vari X II SN # 755707 The horizontal radical keeps sliding down after I have sighted it in. Where can I get this repaired??
The Leupold customer service department handles their repairs. Give them a call at 1-800-LEUPOLD (1-800-538-7653) or (503) 526-1400, and they will be able to determine if the problem can be solved without sending it in, or if necessary, give you specific instructions for shipping the scope to them for repair.
Another option is to send them the information using their online form, if you click this link:
http://www.leupold.com/corporate/contact-us/service-support/
Jan 23, 2011 | Optics
While trying to line my leupold vx-1 4x12 scope up it is shooting low and to right but i am out of adjustment
this could be a scope mount fault,,,but to lift the scope up with some strips of 35mm film under the eye end will raze its point of aim
Nov 30, 2010 | Nikon Tactical Rifle Scope 4-16X 50...
This is my first Leupold scope, I don't understand the friction adjustments 1/2 MOA dials, I need to adjust 3 inches up and 1and 1/2 to the right, I have moved the dials in the direction indicated to no...
minute of angle is not the same as 1/4" per click at 100 yards. if it doesn't click something is wrong. i would call leupold and probably try to get a replacement from where you bought it. moa is an angle value not an inch value.
Oct 23, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
Top turret sticks
Remove numbered turret, check stem for dirt or grim...if it turns hard send it to Premeir under the warranty or email scopeshooter AT yahoo DOT com
Apr 06, 2010 | Leupold 54690 8.5-25x50mm Mk4 Lr/t M1...
The feed dog is not grabbing the material or the presser foot pressure doesn't seem to be working. I have a Viking 6000 SL sewing machine, Model 6460.
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Oct 23, 2009 | Husqvarna Viking 1
Optics Logo
53 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
