Question about Zenith P42w46x 42-inch Flat Panel Plasma Ed-ready Tv With Ntsc Tuner
My zenith on the right side of the tv goes blank
When i hit it a frw times it starts to do fine
I have a zenith plasma tv 50pc3db-ue flatscreen tv and when I hit the power button it goes green then back to red. I believe it is the relay switch. Can someone tell me what pannel the relay switch is on...
Power supply is the big board at the top middle, but a short on any board could do what you are describing, You need a Digital volt meter to trobleshoot further, look for popped or bulged capacitors or shorted components before purchasing more boards. Also look at Y-sus, Y Drivers (big board on the left 2 skinny boards.
Feb 17, 2014 | Zenith Z50P3 50 in. Plasma TV
Zenith C27A24T 27" TV -
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 21, 2011 | Zenith C27A24T 27" TV
TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Apr 12, 2010 | Zenith B27A11Z 27" TV
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
I have a zenith tv hooked up to my computer and i need a monitor driver for it so i can make the settings right now it is using default driver
Make sure Your computer is upto date with the hook up as a monitor setup from the television.If so then do an online search for the drivedr to make it work.
Aug 01, 2009 | Televison & Video
Zenith power will not stay on
Either replace Lamp or Fan is bad.If lamp has been replaced its the FAN, fan must run at all times in order for set to come on and lamp to stay on.
Dec 12, 2008 | Zenith D52WLCD 52" Rear Projection...
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith P42w46x 42-inch Flat Panel Plasma Ed-ready Tv With Ntsc Tuner Logo
20 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
