Question about Maytag PYE2300AY Electric Dryer
Maytag Performa Dryer will not start....
Maytag Performa will not start....I tried three things to no avail...
1: I jumped the start switch by taping (with electrical tape) the two wires together nothing.
2: I unplug the termal fuse and taped those wires together and nothing.
3: I threw the breaker switch and reset it nothing.
Any other tests you think I can try before resorting to calling in a techinician?
Pj
  • 3 more comments
  • westcoast_bc May 20, 2009
    SG...
    First thank you a lot what you brought to my attention blew my mind...I had put the shop vac hose into the vent pipe and heard some stuff coming up but that is not the worse of it what was packed around the blower fan was not only disgusting but well on my way to being a Dryer Fire statistic....I only wished I took a picture of it before starting to vacuum it all up.
    My Maytag part is 31001192 (53-2880) and has 4 wires on it...
    yellow
    grey or blue solid color
    red
    red and white.
    how can I jump it to test this is the problem without the use of a meter? However, based on the what I found I believe this to be my problem.
    While I wait for your respopnse I am off to clean from the outside of the vent towards the dryer.
    Seriously on behalf of my family thank you.
    Pj
    Ignore the previous comment about the 4 wires! I was just so amazed with all the billed up of lint I was not concentrating properly. My Bad!
    Once I re-read your answer I found the 2 white wires and a bit of a bugger to reach but through some manouvering I was able to get to them.
    Long story short everything is operational...however...I will not allow anyone to use the dryer until the right part is back in place.
    Thanks again from me & my family what an awakening.
    Pj
    SG...sorry I might have pressed something wrong. Is there an excellent button because you rocked and I am very very thankful.
    Let me know how I can fix this to read excellent.
    Hey SG...
    I apologize for the downgrade of your solution it was my bad as I was trying to figure out to give you a recommendation I accidentally did the opposite.
    I think I got it right and also wrote the following email to Fixya.
    Thanks again...
    Pj
    Recommendation for Solution Guy…
    I wanted to sincerely express my thanks for establishing the Fixya.com website and having people like SolutionGuy accessible to people like me.
    After trying numerous checks on my dryer I was resolved to calling in a Service Technician to fix the dryer. On Monday night I did one last check to see what if anything I missed in trying to resolve the issue myself and that is when I came across your web page. With nothing to lose and everything to gain I posted my issue on the page and wondered if I would get anything back.
    On Tuesday morning I received an email from SolutionGuy who recognized the issue right away and he also brought a more serious issue to my attention which was lint build up. Going home last night I thoroughly went through the Dryer cleaning a very scary amount of lint which has built up over the years as well as the vent pipe. After I was satisfied with the cleaning I tested the fix which SolutionGuy recommended and it worked perfectly…he nailed it perfectly and the first time.
    I would like to thank SolutionGuy for everything and give him a recommendation for his assistance. Regrettably, I do not know how to do this and would like to ask for your assistance.
    Taking his time and patience to help me was sincerely appreciated and I will be forever grateful for his assistance and will recommend your page to anyone looking for assistance.
    Regards,
    PJ
  • Anonymous May 26, 2009
    I have the same problem with the PYE2300AZW. Looks like I will need the same parts. Thanks for this post and link for the parts. I'll be ordering the tomorrow. BTW I pulled out a small cat from the dryer duct close to the blower.
    President:
  • 331 Answers
Hi West!
Yeah... I know what's happening. Pull all the tape and reconnect all those wires, OK? The problem lies in the thermal overload. It's located on the heater can and below the element terminals. See it down there? It has 2 white wires going to it. When this thing blows, it shuts the whole machine down.
Here's the thing, OK? This is a high limit thermal overload and when this thing trips off, it means that there's another problem... specifically an air flow/ventilation problem. So you can jump out the overload to verify my diagnosis, but don't leave it like that. Google: Dryer fires and check out the video about half way down.
So... yeah, you could jump it and make your dryer work... but you have another issue to deal with after that. Your vent is clogged. Call a chimney sweep or a duct cleaning service to get all that stuff outta there.
Seriously... when your ventilation is obstructed there is a very serious fire hazard present. Please clean your duct work.
SG
Posted on May 19, 2009
  • 1 more comment
  • Tracy Farrell
    Tracy Farrell May 20, 2009
    Hi West,
    I'm glad you found the vent issue and are taking care of it. That'll let you sleep peacefully tonight, won't it?
    OK, the part you described in your response is the control t'stat. That's not the cause of your dryer not starting. That t'stat is there to monitor air temperatures and to control the timer when it's set for "Auto-Dry" or whatever.
    The hi-limit thermal fuse that has your dryer on strike right now is located under the lid behind the drum and below the heating element connection. It's hard to see so I use a flashlight. You'll see where the element is wired in (there are 2 red wires there), about 3" below where the element is connected is the hi-limit thermal fuse.
    The part you'll need is a # LA-1053 <---click the link. It has all the stuff in the kit to take care of this (including instructions).
    Again, I'm glad you got that vent thing taken care of.
    SG
  • Tracy Farrell
    West!
    Why did you down grade my solution?
    SG
  • Tracy Farrell
    Tracy Farrell May 22, 2009
    PJ,
    Your pretty awesome and thank you for your recommendation.
    Look... This is what we do. If I were the tech you called to work on your dryer, I would have told you the same thing. Matter of fact, I see this so often and tell my customers this so often that I feel like I have the script written (emblazoned actually) on the frontal lobe of what's left of brain. I find, however, that telling people something is different than showing people something... like the result of a dryer fire. They hardly ever listen! I have no clue why, but it's true. All of that to say this;
    Thank you for heeding a safety warning. As you saw, lint build up is kind of an atrocious thing to behold, right? And after it's cleared out not only will your Family be safe, but your dryer will perform at optimum efficiency (call it a "green dryer" with a small carbon foot print if you want to).
    Thanks for the very kind words.
    Tracy
I have a Maytag Performa dryer about 5 yrs old. It wont start anymore but makes a humming noise instead.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Performa dryer does not turn on. Nothing happens when I push the start button. It is plugged in and the circuit breaker is closed.
heatman101
Jul 06, 2011 | Maytag Dryers
My Maytag Performa Model # PYE4500AYW has quit. I press the start button and it won't start.
heatman101
Jun 27, 2011 | Maytag Dryers
I have a Maytag Performa dryer and it quit working yesterday. There is nothing coming from it. What should I look for?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 20, 2011 | Maytag Dryers
Maytag dryer does not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair ? The dryer will not start
heatman101
Aug 31, 2010 | Maytag Performa PAV2200
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
DRYER
The door switch is a good start but UNPLUG DRYER and under the top of the dryer is a thermal limit switch lift the top using a putty knife on each side of the lid raise it and on the left rear you will see the element look under the wires going to the element (straight down) you will see a limit switch with two wires on it remove these wires and plug them into each other.make sure they dont hit the frame and plug dryer back in and try to start it if it starts replace the thermal fuse you can tape these wires together with electrical tape and use it until you get the fuse but dont wait 6 months to do so it could cause a fire .Good Luck
Dec 29, 2007 | Dryers
Maytag PYE2300AY Electric Dryer Logo
1,942 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
