Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Rough motor noise
When I turn it on, the brush rotates and it has suction, but the vacuum sounds a lot rougher than usual. Sounds as if the motor is grating or something.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
How old is the sweeper? If it is 5-10 years old the motor is probably wearing out and would need it's bearings replaced. You can replace the whole sweeper for less.
Posted on Dec 30, 2013
Testimonial: "The vacuum is only 2 years old. I took a closer look and I think I know what the problem is. When the motor axel is being pulled on (i.e. by the brush belt), it deviates from its normal axel just a bit, causing the suction fan to grate against a plastic base inside the motor. I'm just going to junk it and get a new vacuum. Thanks though."
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
  • 8404 Answers
SOURCE: dirt devil bagless will not ****.
If it is completely clean, no strain on the motor, no clog, check the fan on the motor - Intact? ... or is the center pulled out of the fan?
Posted on Feb 21, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: brush belt is broken,does this affect the suction
Yes, with this vacuum the belt being broken will cause a loss of suction.
Posted on May 18, 2010
Testimonial: "I suspected this,Ijust didnt want to buy the beltand be wrong..thank you soo much for an honest answer."
  • 694 Answers
SOURCE: there is no suction from the bottom base where the
Check between the brush and the hose connection. It sounds like there's a blockage there. It can easily be pushed toward the brush using a wooden spoon handle, or similar blunt object.
Posted on Mar 08, 2011
SOURCE: M1300 i dirt devil brushes wont roll
the brush roller itself has crud jammed in it. it is not the belt. the smell however - is the belt being burnt as the small metal axle tries to turn the who unit - but the belt wont move - so the small axle spins and burns into the belt. this can burn the belt and melt it and can also stress the motor which is the real pricey repair and not worth it.
pop the roller out of the bottom and hold the very end 'cap' - now spin the roller with your hand - if it doesn't spin with next to no effort - there are probably hairs and threads inside that gumming it up so it wont spin. this is NOT referring to the outside of the roller which can be the issue - untangle any pet or human hairs - carpet strings etc etc - this can solve the issues as well. but regarding the inside turning swivel on the brushroll - some models the end caps come off - some they do not. i put a razor on the sides and cut up some hairs and strings till it was spinning again by hand but it was still not enough to allow the brush to spin on all settings. eventually i was forced to buy a new roller (i have jaguar upright - old model m085830t) - hope this helps -
a few more words of advice - when you buy a vac - once a month or so flip it over and cut out long hairs - threads - and strings - your vac will last forever - if you do this - if it smokes - turn it off right away parts are burning lol
Posted on Mar 22, 2013
The brush quit turning
Sounds like 2 separate motors. remove the beater bar and see f that motor turns without any load. Of not time for a new beater bar motor.
Dec 22, 2014 | Vacuums
Noise
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson vacuum. From your description, it sounds like the model number you've supplied may not be correct, as DC08 is a cylinder vacuum which doesn't use a belt-driven brush bar. So we can confirm exactly which model you own and take you through some quick diagnostic checks, I'd encourage you to contact us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack - Dyson Official Online Customer Surpport
http://www.dyson.com
Apr 25, 2013 | Dyson DC08 Cylinder Bagless Canister...
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Hi, My Kirby Ultimate G upright has very little suction. The engine sounds fine when turned on and the bag is not full at all. Suggestions?
In general, when the beater brushes on vacuum cleaners are not rotating, the debris on the carpet is not "bounced up" and into the suction area of the vacuum. With this in mind it might be a good idea to see if your beater brush or brushes are rotating freely. If they are not it could be due to the ends of the brushes being bound up where they meet the vacuum case or the belt(s) could be loose or broken. That would be the least expensive thing to start with. Please let me know if you have questions.
Sep 15, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Brush not turning and vacuum not suctioning
it probably needs a new bag or could be clogged.
Jun 29, 2009 | Eureka Capture Upright Vacuum Vacuum
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
<2 year old Eureka 4870DT with strange noise and aweful smell from motor. Roller also not rotating. The belt is intact and all tubes are clear. Do I need to replace the motor?
The price of vacuums these days are falling all the time - esp on EBay. This sounds like there's a foreign object or simply dust which has managed to get into the motor thus causing the burning smell or that the roller brush fly wheel is loose and causing friction against the motor. For the price of replacement however you should contact the customer services of Eureka to see how much it would cost either for an engineer or a line diagram to open up the vacuum and do it yourself. Sounds like the motor does need to be replaced or inspected if the pin which holds the belt isn't moving and the burning smell comes out.
Either way this problem can occur if the vacuum has been treated roughly or dropped, or a design fault and usually repair charges mean a new vacuum would probably be more cost effective.
Apr 26, 2008 | Vacuums
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
57 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
