Question about Myers SP25V1 Sump Pump 0.25 HP 115V 10 Cord
Pump does not stop - Myers SP25V1 Sump Pump 0.25 HP 115V 10 Cord
I have a pc22 hooked up to the house. when the water is in use in the house the pump shuts off and stops pumping even though the tap is still on. Is the pump U/S?
no , but the power control is
check for continuous water supply to the pump ( blocked pipe to pump), controller switching of on low pressure and not restarting
you say that the stops pumping indicating that it pumps but then stops so that is why I pass on the pump as a problem
Mar 29, 2018 | Plumbing
Davey presssure pump when switched on b4 tap is opened the pump does run stop run stop run stop between each cycle small squirt of water escapes from pressure tank at the clamped junction
fix the leak as the pump build pressure switches off , the leak looses pressure pump switches on and so on
fix the leak and the pump will build pressure and switch off until the tap is used
Nov 19, 2016 | Plumbing
Water pump stops pumping at ho water pump stops pumping at high RPMs
check for blocked radiator cores
check that if the thermostat is at the bottom hose in the block that it is operational ( opening)
check that the bottom radiator hose is not collapsing at high rpms water pumps very seldom stop pumping unless they cannot get water to the vanes from thermostat is not opening ( too cold or faulty)
radiator is blocked
air lock in system
bottom hose is too soft and collapsing under suction
Aug 07, 2015 | Cars & Trucks
Fuel pump?
replace the in tank fuel pump--its eventually going to stop all together, usually when the tank is full.
Mar 24, 2014 | 2002 Chevrolet Malibu
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
When i turn my steering wheel it makes an awful whinning sound. The first time this happened i put Lucas stop leak power steering fluid in and it stopped. that was mayb a month ago, and now it's doing...
You have a leak somewhere.. If filling the pump does not stop the noise then the pump is going bad. Be sure the leak is at the pump before you change the pump or else the new pump might go bad as well from being low on fluid.
Its likely that filling the pump back up should stop the noise though unless you have run it a while its empty.
Sep 14, 2011 | 2000 Pontiac Grand Am GT
2000 chevy blazer, fuel pump
If the crankshaft sensor is bad, ECM will give no voltage to the pump. It is design to stop the pump running in a case the engine stop during an accident. Check it out. Good luck.
Nov 01, 2009 | 2000 Chevrolet Blazer
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Myers SP25V1 Sump Pump 0.25 HP 115V 10 Cord Logo
Top Myers Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Myers Plumbing Expert? Answer questions, earn points and help others
