Question about Vision Street Wear LVQ-32HLA 31.5 in. LCD TV/HD Combo
I have a vision quest lvq32 hla tv that has background noise as soon as you turn it on
Anybody know if this is common problem or if there is a fix other than throwing out?
Vision quest renoir
First check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Dec 09, 2013 | Televison & Video
Problem with flat screen tv picture
Sounds like a possible "cold" solder joint on one of the circuit boards.
Majority of these intermittent problems is caused by either a broken solder joint and can be fixed if you inspect the different boards that
are present in your unit. Use a magnifier to help you find these "cold"
or "broken" solder joint(s). You will also need a soldering iron (~40W)
and some solder to reconnect/reflow these broken joint(s).
Nov 27, 2013 | Televison & Video
Vision quest tv says tv program blocked
How to unblock a renoir vision quest tv when it says program blocked?
Feb 04, 2011 | Element Electronics FLX-1910 19 in. LCD...
Vision Quest 32inch PVQ-32VGB password not working... locked out
Hi jcbd,
Did you get any solution so far?
I encounter the same probleme with my TV now
Please let me know what you did,
Thanks
By jcbd on Mar 10, 2010
I have a Vision Quest 32inch PVQ-32VGB and the some of the channels have locked and the factory password of 0000 does not work any suggestions? thanks
Mar 10, 2010 | Televison & Video
Tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 07, 2009 | Innovage Jumbo Remote Control
Need a universal remote control code Vision quest Van gogh 42
According to my information this TV does not have any published universal codes as of yet. A call to the manufacturer results in:
" Just use the remote that came with the TV...it's too new to have the codes yet"
Not very helpful are they? IT's a nice Tv for the $$..guess customer support is sacrificed when we try to save some $$.
May 23, 2009 | Emerson EWF2004 20" TV
Vision quest tv problems
my screen is upside down i dont know how to fix it help me!
Mar 27, 2009 | Televison & Video
Does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Mar 13, 2009 | ITT Night Quest 220
Vision Street Wear LVQ-32HLA 31.5 in. LCD TV/HD Combo Logo
20 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
