Question about Filter Queen Majestic Canister Vacuum
NO POWER POWER GOING IN.BUT NOTHING HAPPENS WHEN SWITCHED ON.
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
No power on my pro team proforce 150xp
Generally a bad switch . We have the replacement fix.
Qualitymro.com
Dec 02, 2015 | Pro-Team ProForce 1500XP Commercial...
This is the first time I'm using my Mr Coffee Frappe maker and after plugging in the machine and pushing the power button, nothing happens. Should the red light come on right away?
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
May 19, 2011 | Vacuums
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Not working  I hit the switch and there is no sound of a motor.  Nothing is happening.  It was working seconds earlier and suddenly it stopped.  The plug was in and I replugged it into...
If it was just a broken belt you would still hear the motor running. most likely its in your cord or switch. check the main cord, connections to the switch, and also the motor supply cord that goes from the handle to the vacuum head.
Feb 26, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Our G3 Kirby will not power up?
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
Apr 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Doesn't go on
it could be the switch they do fail. i would test the power do you or someone you know how to use a multimeter if so test the wires for power in the on and off position if it has power to both sides of the switch than it is for sure good if not its bad, if its good test and see if you have power to the motor if it does then the motor is bad if not test power to all items along the wire until you find the place where the power stops and that will be your bad part.
Nov 29, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Filter Queen Majestic Canister Vacuum Logo
20 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
