Question about Pioneer SD-643HD5 64" Rear Projection Television
Pioneer rear projection tv remove front screen
techman
  • 3130 Answers
SOURCE: Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Posted on Aug 13, 2006
  • 1153 Answers
SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Posted on Sep 17, 2007
  • 2920 Answers
SOURCE: red shadow?
call a tech and have them converge the tv.its either that or the focus
Posted on Jan 02, 2009
welcomejee
  • 10594 Answers
SOURCE: blue tint on rear projection tv
Sounds TV requires White balance / Gray Level adjustment.
Please turn color level minimum and let me know do you see pure black and white picture or its bluish?
Please post back in comments and intimate exact model of TV.
Posted on Mar 14, 2009
asnowman
  • 788 Answers
SOURCE: how to remove front screen
The screen comes off from the front. First take off the speaker grill and you can access the frame screws they are right below the screen. This only takes off the frame with the filter. After the screws are out swing the bottom out a bit and lift straight up on the frame then pull it out away from the set. I have found these to be very stubborn somtimes, but you should be able to get the frame to move then work it up and off. I hope this helps you. let me know if you have any more quesitons.
Posted on Apr 30, 2009
Tell me how to clean my bulbs and mirror of my pioneer SD-643HD5
You will have to remove the Front Screen ,First remove the bottom Panel and then the screen.
Jun 29, 2011 | Pioneer SD-643HD5 64" Rear Projection...
My screen was damaged and I finally found a new screen for it. How do I get the molding off so I can replace the screen?
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Sep 26, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
Need to replace front screen. can i do this from the front? can i purchase this front screen material from anywhere other than pioneer
Try finding one on Ebay under TV Parts ,Electronics and Try Encompass Parts Distribution type in your Model number and see if they are listing Screen replacement or call 1-800-638-3328
You can also Call local TV Shops to ask do they have a good used one for sale.
Jul 10, 2010 | Pioneer SD-641HD5 64" Rear Projection...
My screen broke how do I replace it? I have a 50 inch pioneer rear projection tv. I just want to replace the screen
You will need to remove the bottom panel then screws holding it on, screen should slide up and out.
Jun 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
How to remove front screen
Apr 28, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Replacing rear projection glass on Pioneer Pro-620HD
1)Pioneer entry is through the front,as you already found out.
The service manual will show you.......
2)Remove lower front speaker grill
3)Remove screen frame only
4)Choose left or right side to remove rail to access screens
5)CAREFULLY slide screens out to expose interior
6)Replace mirror and wipe off RGB lens caps
7)Reassemble .......................go slow,.............T.
Jan 25, 2008 | Pioneer PRO-620HD 58" Rear Projection...
Pioneer SD-P40
Check to see if Q118 is shorted on video/defl pc
Aug 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
89 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
