Question about Pioneer SD-643HD5 64" Rear Projection Television
Pioneer rear projection tv remove screen - Pioneer SD-643HD5 64" Rear Projection Television
techman
  • 3130 Answers
SOURCE: Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Posted on Aug 13, 2006
  • 375 Answers
SOURCE: Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Posted on Aug 18, 2007
  • 1153 Answers
SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Posted on Sep 17, 2007
  • 2920 Answers
SOURCE: red shadow?
call a tech and have them converge the tv.its either that or the focus
Posted on Jan 02, 2009
welcomejee
  • 10594 Answers
SOURCE: blue tint on rear projection tv
Sounds TV requires White balance / Gray Level adjustment.
Please turn color level minimum and let me know do you see pure black and white picture or its bluish?
Please post back in comments and intimate exact model of TV.
Posted on Mar 14, 2009
My screen broke how do I replace it? I have a 50 inch pioneer rear projection tv. I just want to replace the screen
You will need to remove the bottom panel then screws holding it on, screen should slide up and out.
Jun 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Red shadow?
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
Manual for Pioneers Flat Screen TV
Contact me I can get you a copy of manual for $25.00 Camale001@hotmail.com
Dec 15, 2008 | Pioneer SD-532HD5 53" Rear Projection...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Replacing rear projection glass on Pioneer Pro-620HD
1)Pioneer entry is through the front,as you already found out.
The service manual will show you.......
2)Remove lower front speaker grill
3)Remove screen frame only
4)Choose left or right side to remove rail to access screens
5)CAREFULLY slide screens out to expose interior
6)Replace mirror and wipe off RGB lens caps
7)Reassemble .......................go slow,.............T.
Jan 25, 2008 | Pioneer PRO-620HD 58" Rear Projection...
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
20 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
