Question about Sony Televison & Video
My TV is just bliking its power indicator and automatically off.
My sony TV is just no power only the power monitor is blinks 3 times and it automatic off.
Sounds like a power supply problem. Depending on the Sony model, the blinking may be a diagnostic code to indicate the specific problem. It is most likely this:
3 Blinks = B+ over voltage protect
Sony sells the service manuals for their TVs and you should be able to find this info out for sure. My recommendation is to buy a new tv.
Posted on May 19, 2009
I have a tv ti blike 4 times and dont tun on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 22, 2014 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
D61W20 61 in. Rear Projection Television: turn on tv ligt blinks 3 times and goes out....
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Televison & Video
SONY KV35S40 Light blinks continuously when power is pressed
hello there,
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
May 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony tv go
hello 5 blinks mean akb circuit automatic kine bias the timer indicator blinks for 30 seconds then goes in to self -diagnosis function something is wrong with the video check out Q705/732/761 and other components on the c board also check Q218/219/220 on the a board
in addition,unit could be in ik blanking try turning up the screen slighty good luck
shaun
Jan 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV cannot be turned on
Please count the blinks. It should be a repeating count with a pause. This will indicate the problem circuit and allow us to give you details.
Thanks,
Dan
Jul 03, 2008 | Sony KP-53S65 53" Rear Projection...
Power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Jun 23, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
