Question about Dell E172FP 17" LCD Flat Panel Monitor
Lost power cord for sound board
How do we get a replacement
    Master:
  • Dell Master
  • 788 Answers
Browse ebay website.
Posted on Mar 01, 2014
I lost the power chord to the remote on my George sound system by Chestnut Hill
unfortunately it seems the George is no longer available. However, the power cord is a USB cord then you should be able to replace it by picking up a multiple USB cord kit (the one that has both the standard and mini sized cords).
May 23, 2014 | Apple Chestnut Hill Sound GEORGE Compact...
TV lost its power. will not turn on. Tested power cord and its fine.Plugged into another outlet and still will not turn on.
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 12, 2010 | Protron PLTV-32 Television
Lost picture and sound. Is there a rest button or a reboot procedure? or is the board toast??
Try unplug,replug the tv an hour later.That to reset the tv,back to the factory setting.Tv should work now.Not,the power supply board is dead.Common problems on LCD tvs.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 07, 2010 | Vizio VX32L Television
Samsung SCX-4521F Possibly lost its power? When
If it just make tick sounds, but does not power up and does not do its normal startup, it probally the power supply board on this printer has failed. This printer like most modern electrical appliances has a switching power supply. The ticking sound is the power supply trying to start, but it senses a fault and shuts down and tries to restart.
I had a similar problem with my printer, though it not the same model (CLX-3160) but the same manufacturer Samsung. I took mine appart and found that one of the capacitors on the power supply had failed. It was blown and the top of the capacitor popped open. I am not saying this is your problem but it would be the first thing I would check if you want to get this fixed. Otherwise, look for a new printer.
Hope this helps.
Jun 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
This one powers up, and displays for a second, but shots off after about a second.
U still have Sound?Or the power just dies?Tries websites Ebay.com,Shojimmy.com to buy the 2 reburbish LCD inverter boards,it a long boards,to replaced if still have sound.Replaced the 2 long LCD inverter board will get ur picture back.If power dies than buy the power supply board for the replacement.The power supply board is the board where the power a/c cord plug into it.
Jun 09, 2010 | Protron PLTV-3750 Television
I have a 2 yr old dell inspiron 1525 any time i plug a working power cord in it turns the power off to the cord(green light goes off) i tried two different cords and both times they lost power as soon as i...
Unfortunately, it sounds like you have a bad motherboard... I've seen this one a few times. There's a very tiny chance the DC jack you're hooking it into is bad (this is soldered onto the board), but more than likely the board itself is bad. Because of how cheap laptops are nowadays, it may be just as cheap to buy a newer (and faster) one than to get a replacement board for that one, if you're out of warranty.
Nov 10, 2009 | Dell Inspiron 1525 Laptop Jet Black
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Jerry
Nov 07, 2008 | Philips 36PT842H 36" TV
Unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
Feb 17, 2008 | Harman Kardon AVR 25 MKII
Dell E172FP 17" LCD Flat Panel Monitor Logo
Alun Cox
