Question about LG Refrigerators
Hi, my LG frost free refridgerator is not as cold as it use to be, from 6 degrees now im putting it on 0 degrees but still theres no change, what could be the problem?
  • 468 Answers
The condenser coils could be plugged with dust and lint. The coils need to be able to get rid of the heat for the unit to cool properly .
uplug unit remove lower fiberboard cover and clean coils carefully.reassemble and see if that does it . Check fan if there is one for proper operation. Hope this helps
Posted on Dec 29, 2013
  • 76 Answers
SOURCE: lg frost free freeza ok
Well the first thing to think about is: Is it pluged in??? the second thing is that you should call a repair man to make sure the job is done right. Hope this helped. =)
Posted on Feb 25, 2008
  • 172 Answers
SOURCE: I get excess frost on
Hello Monkeyhouse,
I live in a monkey house of my own with two little girls climbing on everything. If your house is like mine the main reason for frost build up is warm moist air entering the freezer. My children love to open the door all the time so I get some frost from that. If you are really getting alot then you may have a crack in your seal around the door. or the door is not sealing completely. To solve the problem you can adjust the door or you can replace the seal. Replacing the seal is really harder than most people would care to tackle. But if you discover a bad spot on the seal this is the best way to replace it. First would be to buy you a seal and start it soaking in hot hot water. This will loosen the rigidity of the seal and help with seating. Once the seal is soft begin removing the old seal. You can do this byraising the inside of the seal and loosening the screws. Do not remove the screws completely just loosen enough to remove and replace a small section at a time. work the new seal around and once you feel it is perfectly centered on all sides tighted the screws. If you still have waves or the door is not sealing you may need to reheat the seal with a hair dryer. Use caution not to burn the seal or overheat the seal.. Over heating will cause it to shrink and it will never work. Good luck to you and please let me know it this helped. MCA0824@aol.com
Posted on Apr 30, 2008
  • 19 Answers
SOURCE: defrost cycle is not working
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # off your data plate ready.
Posted on May 09, 2009
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
SOURCE: freezer is cold but refridgerator is warm. older
Your defrost circuit is probably broken.
Are you getting lots of frost on the bottom of your freezer?
Is there any airflow in the top portion of the fridge? You can test this by blowing a little cigarette smoke into the refrig section to watch the air pattern.
If you have excessive frosting above and no air below....it may be time for either a new heating element or a defrost controller board.
Some older units allow you to just turn on the defrost circuit and see if the heating element has gone bad. You may want to buy the controller first if it fails the forced power on test. Then, if that doesnt do it...you can buy and replace the heating element.
Good luck and be careful.
Posted on Feb 03, 2010
Frigidaire problems
Use the link below to view and read the user manual. If this is a used refrigerator it is possible that there may be a problem but it should be minor. The refrigerator section is cooled by air from the freezer. This problem is usually caused be excessive frost but you should not have frost buildup in only 24 hours.
There is also parts lists and diagrams.on the site.
I am also including a link to youtube videos about refrigerator problems.
FGHT1832PF0 FRIGIDAIRE REFRIGERATOR Manual
Frigidaire FGHT1832PF freezer cold refrigerator warm YouTube
Sep 04, 2014 | Frigidaire FGHT1832PF Gallery Series...
My freezer in my side by side refridgerator has frost developing around the ice maker. There appears to be a leak somewhere. Any ideas as to the cause of the frost? No matter where I set the temp, frost...
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Refrigerators
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
Firdge turns on but never gets cold. Runs constantly. Refridgerant maybe?
Is the condenser fan turning? Is the evaporater fan turning? Check the evaporater at the freezer compartment it should have fine frost all the way if no frost or partly frosted may be low on freon.Be sure there is no air leaks around door or something. Hope this helps.
Dec 23, 2010 | LG (LRBC22522ST) Stainless Steel
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Refridgerator temperature
I think it may be a defrost system problem. If you have frost on the back wall the problem is related to the defrost timer or defrost heaters or thermostat.
Also check the condenser for dust. If plugged with dust the system can not get rid of the heat. If dust is present clean it out completely.
Remove the toe plate under the refrigerator door to check the condenser.
May 24, 2008 | LG Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerator cooling problems
check the refrigerant level or efficiency of the compressor.if it is a frost free fridge,check that the fan is working ...oh and could also bee a blockage in the system.change drier properly vacuum and regass system.
Nov 05, 2007 | Refrigerators
Freezer works fine refridgerator does not
problem may be that the return vent from freezer to fridge is blocked with ice. best solution is to switch off for 24 hours with doors open. 2 hours may not be long enough to clear this blockage
Jun 13, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
