Question about Kenwood Juicers
Removing lid off kenwood older model juicer
Hi have used juicer today but cannot remove lid as seems to be locked for cleaning have tried for at least one hour,is some years old with a small gap on top for cut up fruit
SOURCE: Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Posted on Dec 12, 2008
SOURCE: How do I remove the filer cone for cleaning?
I suggest pick it up by spout & other side of bowl & shake a little & it should release from the base unit
Posted on Feb 22, 2009
SOURCE: jack lalanne juicer, 8 yrs.old model?
A general solution for most Jack Lalanne juicers.
Before removing the filter u must remove the steel blade , usually using a two pin tool provided; Then wiggle out the strainer basket. If u have not cleaned during ur previous use, there could be dried juice that needs softening wirh a damp cloth. Please go to Jack lalannes official site to get their phone no. , they will be happy to help u.
zahid@uic.edu
Posted on Mar 10, 2009
arthurbau
  • 139 Answers
SOURCE: juicer will not start when switch is turned on
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Posted on Apr 04, 2009
I have the Nutri-Max juicer by Rotel and would like to know how to take it apart for cleaning. Model #7909
Hi, It should be just a matter of releasing the 2 side clips then remove top plastic cover, it may be stuck with sugar syrup from a previous use and could need a little force.
Jun 12, 2014 | Jack Lalanne Power Juicer 250 Watts
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
TRY INVERTING IT AND SOAKING IN A
SOLUTION OF OXI CLEAN AND HOT WATER.
Jun 28, 2009 | Juicers
How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Given a kenwood je500 juicer
email me at ewingelectrical@optusnet.com.au I have a PDF file that may help.
Apr 28, 2009 | Kenwood Juicers
Jack LaLanne Juicer
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
Top Kenwood Juicers Experts
David Payne
David Payne
eyecam
Mark Schmit
Mark Schmit
Are you a Kenwood Juicer Expert? Answer questions, earn points and help others
