Question about Kenmore HE2 Plus Front Load Washer
Buzzing/Ratcheting sound while drying
My Kenmore HE2 Plus dryer has begun to make a buzzing, almost ratcheting sound intermittently while spinning. The clothes are being dryed, but the noise is very loud.
  • mom2kidds May 26, 2009
    my washer seems to make more & more noise that it didn't use to. the load is balanced, not over loaded, is washing and draining but now a 'ratcheitng' sound while draining/spinning. Pump? Is that something we should try to examine or repair on our own or is it best to call a repair person? Sears repair is $109 min service call to our area. Yikes!
    Sergeant:
  • 187 Answers
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
Our he2 dryer is flashing a F
Get online ask Kenmore.Did u lose book?
Aug 12, 2012 | Kenmore HE2 Plus Front Load Washer
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
My clothes are taking up to 4 hours to dry..
Verify unrestricted air flow at the outside discharge port for the dryer. If in doubt, pull the hose from the rear of the dryer, turn it on and form an opinion about air flow volume, then outside must be very similar.
Jun 08, 2011 | Kenmore HE2 Plus Front Load Washer
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
412 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
