Barrier Diode Failure
I have an HP Pavillion DV1000 Laptop that I'm working to repair for a customer. I have mostly isolated the issue to be a failed SBM1040 Diode near the DC power input and have located some sources and more modern alternatives (the PDS1040 Diode) however, before I order the needed pieces (this is labelled PD21 on the motherboard), I'd like to make sure that I wouldn't really need to be looking to replace a couple of other components in that area. I know these notebooks have horrendous heat problems and that this is likely to be the cause for the failure so I figured I'd check before getting the pieces to repair if anyone has experience in performing the job.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
You seem to know what you're doing, but make sure the diode only works one way. If it doesn't work at all, then it will need to be replaced, if it works both ways, it could have damaged other components.
This laptop is quite old and personally I wouldn't have bothered with it, since as you know, these laptops are terrible for these sorts of problems!
Posted on Jan 06, 2014
4 Suggested Answers
SOURCE: HP Pavilion dv4000 PC Notebook Power jack problem
I am sure that power jack is a part of your mother board but you can also replace a new power jack for your mother board. I know that if you send it to HP they will charge you 398$ for repairing the notebook. I will give you a link from where you can purchase a power jack with a nominal price. You can fix it by yourself or you can go to any electronic shop for foxing this. It is as simple as soldering the new power jack on the mother board.
The web link is:
http://www.laptopjacks.com/product/HP-Laptop-DC-Power-Jacks.html
Regards,
Krishna Teja
Posted on Mar 08, 2008
gnkanang
  • 63 Answers
SOURCE: I'm after the HP Pavillion ze5600 notebook series service package
There is an .exe file on the HP site. I'll admit it was pretty well-hidden on their site. Here's the link to the EEPROM programming tool:
http://h21007.www2.hp.com/portal/site/dspp/menuitem.863c3e4cbcdc3f3515b49c108973a801?ciid=29627f45a64ca110VgnVCM100000a360ea10RCRD
Posted on Mar 26, 2009
SOURCE: Gateway MX6453 or MA3
Because the power jack is soldered directly to the motherboard, side to side stress on the plug over time damages more than the solder joint, it also loosens the little copper sleeve that lines the hole in the motherboard. Simply resoldering the joint only cures the problem for a month or so. You must remove the plug, wrap and then solder a thin piece of wire clipped from a small resisitor lead to the base of the center pin connector leg (the one to the back of the jack) and pull through the board with the leg. Then the extra wire is bent over like a hook and coiled around the spot -- squashed flat. then the coiled extra wire acts as an added anchor when soldered (hooking the power jack connector to the board.) this joint will survive like or even better than new. Not doing this added step gaurantees you joint repair will fail not long after it is made.
Posted on May 17, 2010
HP Pavilion Laptop -- massive power problems?
hello chad
Seem to be circuit issue.
You can check charger with volt meter to check its working ok.
Drain all resistors of power by removing battery and charger and holding down power button for 10 seconds.
There is a power button board that can be bad.
I like to break things down by just powering the laptop with memory and keyboard, power button board only. this will require removing motherboard power button board so it will only be the parts to POST.
Minimal Post .
It can be an array of things from the systems casing shorting it out to other hardware.
Jan 04, 2014 | HP Pavilion dv1000 Notebook
HP DV1000 won't run normal after a forced shutdown
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Oct 28, 2012 | HP Pavilion dv1000 Notebook
My hp pavillion dv1000 laptop fan doesnt work..
Have to try to update the BIOS on your machine? usually that's what HP support do, you can download the BIOS driver to HP website. If happens that you already updated the BIOS and still the fan is not working, it means that the Hardware is faulty.
Feb 27, 2011 | HP Pavilion dv1000 Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Letters keep typing even without keyboard
I'd try wiping and reinstalling the operating system or booting from a linux live-cd first to see if it's a windows issue or hardware issue. In the end though, yes I believe the motherboard is probably faulty.
Jan 22, 2010 | HP Pavilion dv1000 Notebook
I have a dv1128ap laptop, last night suddenly black out and now can't turn on.
Remove the battery and the hard disk and try to boot into the BIOS - if it fails then it's a massive hardware failure, nothing you can do apart sending it to a repair shop. Beware, most likely it will cost you a lot just to hear that is irreparable.
Jan 17, 2010 | HP Pavilion dv1000 Notebook
I used windows vista on ma hp pavillion dv1000 but i didnt worked properly....no audio drvers detected not even supported and as well as some of others too... i need drivers info related to my dv1000
hello
you reis goninstall your system factory setting and your problem e i advise to u use ur laptop very softly
you can give me high rating for this help
please
Oct 23, 2009 | HP Pavilion dv1000 Notebook
HP Pavillion dv1000 laptop will not power on
Cold solder on DC connector. Most common problem.
Feb 20, 2009 | HP (367799-001) Motherboard
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
