Question about Pride New Mobility Celebrity 3 wheel Scooter
Normal performance 10 min of use then drags like brake on loses speedbrake assy gets hot unlock freewheel and pause relock will help run better for awhile
Brake assy get VERY hot takes longer to recharge then normal
  • Pride Master
  • 1,271 Answers
Hi, now there it could be one of two faults, the brake magnetic core is not releasing the brake after a period of time, it's breaking down , other-words it's dragging or the voltage from the controller is not high enough or not enough current , a controller fault...check the wiring going from the controller to the brake... now a simple test would be to remove the brake but still have it connected via the two wires and tape on to the motor now you must be careful here because the scooter will roll if near a incline etc...so you been warned !!!! ... does the scooter run okay now ?
I do repair brakes..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Dec 30, 2013
Pride Celebrity x. Batteries drain quickly despite new full charged batteries. When scooter is pushed in freewheel- brakes engage every few feet. Have to turn scooter on/off to get brakes to release.
hi Diane, the brake engaging is by design, distance is the key here
Have you tried another charger ?
1. when pushing the scooter in freewheel before the brake engages , is it easy to push ? what can happen is the brake does not release 100%, a easy test is to run the scooter then put your hand on the brake unit , is it hot ? be careful because it could be very hot , this will prove the brake is not releasing fully.
Regards
Rob
Dec 09, 2015 | Pride Health & Beauty
Re: Pride Celebrity X. Batteries drain quickly despite new fully charged batteries. Also when scooter is turned off and in free-wheel, the brake engages after just a few feet. Have to on/off to reset
New Batteries must broken in, For the first 20 Charges, do not allow the power level to go below half way before recharging. Charge the batteries in a warm environment. Also, if charging in a cold environment the batteries won't get the best range. Batteries have 60% of their capacity when the temp. is 32 degree F. At 0 degrees F. the batteries will only have 40% of capacity. Batteries have shrinkage. Good news the capacity best at 80 degrees.
If the brake is hanging up, it will cause drain on the batteries. A sure sign is, if they are hanging up is after 10 min. of running the brake will be very hot to the touch. It sometimes turns the brake blue in color or rusty.
The brake engaging while in freewheel mode is supposed to be a safety, to keep run-a-ways from occurring. I agree with you it is aggravating when you try to push the scooter. Scooter Doctor App
My boss has an Elite Traveller that won't move. The battery is fully charged and its in the unlock position. Please advise. Thank you in advance for your help.
  • When the manual freewheel lever is pushed forward, the brakes are disengaged and all power to the motor/transaxle assembly is cut.
  • Pull back on the manual freewheel lever, turn the Travel Scooter off, and then back on to return to normal operation.
Feb 01, 2015 | Elite Health & Beauty
Chirping sound in motor, brake assy HOT, lugs unlock pause relock will improve power loss cel-leb X
Hi, now there it could be one of two faults, the brake magnetic core is not releasing the brake , other-words it's dragging or the voltage from the controller is not high enough or not enough current , a controller fault...check the wiring going from the controller to the brake... now a simple test would be to remove the brake but still have it connected via the two wires and tape on to the motor now you must be careful here because the scooter will roll if near a incline etc...so you been warned !!!! ... does the scooter run okay now ?
Regards
Rob
Dec 29, 2013 | Pride Health & Beauty
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Controller light is flashing and chair will not move
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Oct 03, 2010 | Pride Go Chair Travel Power Chair
My '97 dodge neon will not start when it's hot outside. When it's cooler like in the morning it will start and run fine. My car will also stall out if it gets too hot. It's not an over heating problem...
Try changing the coolant sensor. I'll bet your gas mileage is less than normal too. The sensor is not reading correctly when hot & is not allowing the computor to advance the timing to adequate levels thus the poor performance. It is located near the thermostat housing. You may lose a little antifreeze when you remove it. Also if you unplug the sensor when the engine is hot, it will run much better in the meantime. Just plug it back in for start up. Hope this helps you. Good luck!
Aug 08, 2010 | 2000 Dodge Neon
Dryer runs foe a while 10 min. the it shuts off.
sounds as if you hav a bad motor assy, its tripping off on an overheat thermo and resetting when cools off, replace the motr assy
Nov 13, 2008 | Speed Queen AES28AWF Electric Dryer
Gps loses signal
It would be good to make sure that the 951 software is up to date. The most recent software upgrade includes new code required due to changes that have been made to the GPS system. You can download the software for free from the Northstar web site but it requires a loader cable, power supply and a Windows based PC to perform the update. Most Noprthstar dealers know how to do this but they will charge for their time. The GPS antenna should be mounted where it has a 360 degree uninhibited view of the sky right down to the horizon to get best performance. Basicially any conductive material including pigmented paint, tinted glass or wet canvas can block the signal. Inspect the GPS coaxial cable and it's connections for any signs of corrosion or contamination. Sometimes just removing and reinstalling the connections is enough to remove contamination and get better performance. If in doubt concerning the coax and it's connections, temporaily substitute a new coax assy by-passing the existing cable to see if this makes a difference. You can monitor changes from the GPS status page. See the user manual for information concerning how to understand the numbers being presented. You should be tracking at least 4 SATs with signal levels higher than 30. Generally 95% of all GPS signal issues are related to the coax or its connections.
coax assy to v
Jul 26, 2007 | Northstar 951XW GPS Receiver
Pride New Mobility Celebrity 3 wheel Scooter Logo
62 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
